Transfer case fluid change
Old Oct 30, 2006 | 06:37 PM
crazylewi's Avatar
crazylewi
I have a 95 ps with a 5speed trans. I am going to change my tranny fluid with the royal purple synchromax. What kind of fluid should I put in the transfer case?
Old Oct 30, 2006 | 06:56 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The tranny and transfer case are both designed to run ATF. I use Royal purple max ATF in mine.
Max ATF is what RP recommends you use in place of Mercon.
Old Oct 30, 2006 | 07:12 PM
1997F-350's Avatar
1997F-350
thats exactly what i got in mine(synchromax). used rp syn atf in the xfer case also.. been going strong about 20k in about a years time.
