Tailgate opening by itself
Old Apr 24, 2018 | 09:53 PM
  #151
NHbum's Avatar
NHbum
Smile
Originally Posted by expy03
Would it be so difficult for Ford to put out a TSB about adding Di-electric grease to the connection under the tailgate? Or better yet do it at the damn plant while The trucks are being assembled. It would probably fix 90% of the tailgate issues and save them 10’s of thousands of dollars in harness replacements.
Now you know anything that makes sense isn't going to happen lol
Old Apr 24, 2018 | 10:20 PM
  #152
briangp's Avatar
briangp
Makes me glad I got my XL, but I also wanted to put in my two cent for those of you who are concerned that you have no idiot light to tell you the tail gate is open....
Go get a pin switch, wire one end to ground at the tailgate. Install the pin switch and set it so that it closes when the tail gate is open. Run the other end of the wire into the cab, tie it into a flush mount LED, wherever you'd like it, and finish off the circuit at the battery or some other constant 12V source. Bam, instant idiot light, probably cost about 10 bucks and a half hour at most of your time.
For those who are more savvy, you could probably tie it into a door switch to give you a warning on your instrument cluster, but it isn't going to specifically read tailgate, unfortunately. Fixing it should be easy for y'all now that you know which connector it is. Plug that **** up with some dielectric grease and flip the connector over so it doesn't catch water anymore.
Lastly, a mildly electronic savvy person could design a relay to cut all power to the actuator unless the truck is in park....
Just a few ideas for you folks, Sorry this ****'s happening.
Old Apr 25, 2018 | 06:13 AM
  #153
VoodooRob's Avatar
VoodooRob
Here is another update on our 2017 F350. Just turned 4,500 miles and ownership is at 8 months. Phantom tailgate was our 1st aftermarket option added a few days after purchasing the truck. After stuffing both connectors "aft" of the spare tire overflowing with dilectric grease, I have not experienced any tailgate Phantom operarion. Bear in mind both of the connectors were full of water.
Old Apr 25, 2018 | 08:39 AM
  #154
Y22man's Avatar
Y22man
Originally Posted by backtrack2015
The thought of having the tailgate drop while pulling a fifth-wheel is a bit scary. I doubt I'd notice until after the first few turns.
I'd be willing to go clip a wire and lose the auto-opening feature. I like the power lock, but I'm happy to skip auto-opening if it isn't bulletproof. I expect it isn't quite that simple.
i had had this happen to me over Easter. I now do not trust the tailgate. I have everyone check before I leave. Damage to trailer and tailgate.
Old Apr 27, 2018 | 07:51 PM
  #155
expy03's Avatar
expy03
Same here, 5200 miles on my ‘18 250 and have had no problems since following VoodooRob’s advice.
Old Apr 27, 2018 | 08:06 PM
  #156
Deadbuck's Avatar
Deadbuck
Originally Posted by 43davel
Since when is it necessary to have and pay for all those sissy options anyways? Electronic tailgate releases to help you load your groceries, adaptive steering so you can check your text messages, blind spot warnings because you don't know how to use those huge adjustable side mirrors and all the other nonsense today. Good luck with all that...
go buy a Chevy or dodge then
Old May 22, 2018 | 07:19 PM
  #157
billnesbit's Avatar
billnesbit
Hey everyone, Since getting the tailgate fixed, I had the tailgate drop on two occasions. What I found is that the release button is super sensitive. I barley ran my finger over it and it released the tailgate. I have since installed a safety lanyard to prevent the gate from dropping all the way while towing my toy-hauler. Got the idea from this thread and it saved the tailgate from any new damage.
Old May 23, 2018 | 12:15 AM
  #158
cdnfireman's Avatar
cdnfireman
i found the same. I barely brushed the switch reaching for the park brake release and it triggered and opened the tailgate. I unplugged mine since I have no need to open the tailgate from inside the truck. I can see how the impact from the park brake pedal sometimes sets it off
Old May 23, 2018 | 02:03 PM
  #159
CaptJaC's Avatar
CaptJaC
X2 It took less than 5 mins to pop open the trim piece and access the Switch and unplug it.
Old May 26, 2018 | 02:56 PM
  #160
Brent missouri's Avatar
Brent missouri
Me too! Key fob in pocket.
Old May 26, 2018 | 03:16 PM
  #161
HRTKD's Avatar
HRTKD
I tried this today on my truck. Simply running my finger across the switch did not activate the tailgate. I had to explicitly press the tailgate release button on the dashboard to get the tailgate to drop.
Old May 26, 2018 | 07:42 PM
  #162
cdnfireman's Avatar
cdnfireman
mine was very touchy. Horizontally across the switch was fine. Vertically over the switch like your hand would be going for the park brake release it was too easy to actuate it for me.
Old May 29, 2018 | 11:24 PM
  #163
hobbie1's Avatar
hobbie1
My 18 dropped the tailgate yesterday and I'm pretty sure I know why.
Reached down to release the brake and my thumb bumped the tailgate release. Did not even notice till I put it in reverse and the reverse sense went crazy.
Ford needs to do one of the following:
1. Make the switch less sensitive
2. Change software to require 2 pushes to drop the tailgate
3. Move the switch away from the parking brake
Curious will the gate drop while your moving? I should test?
Old May 30, 2018 | 05:27 AM
  #164
senix's Avatar
senix
Is there enough of the wiring harness that you as the user could move the switch to a new and better location?
Is there an option in the settings menu to disable the switch or key fob access to the tailgate?
Old May 30, 2018 | 05:39 PM
  #165
AMXDREAMER's Avatar
AMXDREAMER
disconnect the switch, it hasn't happened in the year since doing this. It is super sensitive and the vibration from the parking brake release could activate it. It has a button or the fob if I want it open. I really like the power down button on the remote. Makes loading stuff easier!
