Sponsored by: Real Truck
Underseat powered sub
Old Feb 16, 2017 | 06:44 PM
Slammer1's Avatar
Slammer1
Anyone power a sub using the upfitter switches? I will be using the line level inputs with remote turn on. Have a friend who offered to give me his Kicker HS-8 powered sub.
Old Feb 16, 2017 | 09:14 PM
rickbrad's Avatar
rickbrad
There is no reason you could not use an upfitter switch. But why use one up for that? You are going to want your amp to turn on any time you turn the truck on, so just use an accessory powered wire.
Old Feb 16, 2017 | 09:22 PM
Slammer1's Avatar
Slammer1
Just trying to avoid running monster cable through the firewall and connecting directly to the battery.
Old Feb 16, 2017 | 09:33 PM
rickbrad's Avatar
rickbrad
Those switches are not rated for the kind of current you are talking about. I thought you were referring to the remote turn on wire! You have to go straight to the battery with 4 ga. wire. There are plenty of places to put it through the firewall.
Old Feb 16, 2017 | 09:34 PM
Slammer1's Avatar
Slammer1
Will do, thanks for the info!
RangerPilot
Oct 31, 2005 05:13 PM
kurtisp
Dec 21, 2003 07:22 PM
tayz34
Sep 29, 2003 08:29 PM
snakebit
Jul 11, 2003 09:18 PM
wolverineflight31
Sep 8, 2002 04:52 PM
