Sponsored by: Innova
Amp Won't Turn On
Old Dec 19, 2003 | 08:05 PM
kurtisp's Avatar
kurtisp
Unhappy Amp Won't Turn On
my amp will not turn on......i hooked the remote wire to the specified wire on the cd player and that din't work.........sooooooooooo........i tried hooking it to the fuse box to the radio fuse..........STILL dose not come on........is there any way to see if anything is wrong??>>>>>
Old Dec 19, 2003 | 08:42 PM
triton_2002's Avatar
triton_2002
Check your ground, make sure it's a clean connection. Check your power wire and fuses. If still nothing, bypass the remote wire by connecting it to the power wire. If it works the problem is with the remote turn on, but if it works don't leave it like this or your amp will never turn off and your battery will die. The remote turn on (blue wire) and the power antenna (blue/white wire) are not the same (depending on your HU). Hope that works.
Old Dec 20, 2003 | 12:37 PM
chingao81375's Avatar
chingao81375
I would first check if the amp is the problem. What i used to do is ground amp and then touch hot wire directly to the battery if it does turn on then its not grounding good in the vehicle or wiring is faulty. but if it doesnt its either a fuse on or in the amp or the amp itself is defective.
Old Dec 20, 2003 | 05:24 PM
drunkenmonk's Avatar
drunkenmonk
to turn an amp on you have to power the power terminal, and the remote terminal
Old Dec 20, 2003 | 09:15 PM
kurtisp's Avatar
kurtisp
it worked............the ground was great at all..........all fixed thought..............thanks!
Old Dec 21, 2003 | 07:22 PM
triton_2002
kurtisp
So what was the problem? I'm sure eveyone whould like to know
