89 f350 ignition problems!!!
Old Jan 29, 2017 | 03:22 PM
Free350's Avatar
Free350
Question 89 f350 ignition problems!!!
My truck was having ignition problems... would lose power to the stereo and other random dash lights. It would also stall randomly when changing gears or if the key was knocked even slightly...
So, I started poking around (with the battery still attached, like an idiot) and found that the ignition switch was loose. while trying to seat it properly it crossed a connection, there was a burning popping sound in the engine compartment... ... now nothing!
I've replaced the solenoid switch, the key lock cylinder, the main relay (EEC) fuse, and tested the ignition switch itself for continuity (which it has).
Someone Please Help!!! I dont know what to do next...
afterthought:
when I check for voltage at the main ignition plug (wire harness that goes into the switch), at the two larger yellow wires I only read 2-3 volts per... ...
Old Jan 29, 2017 | 11:47 PM
ChRoNo16's Avatar
ChRoNo16
probably fried your ECM.
Old Jan 30, 2017 | 07:35 AM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE.
check the fuseable links at the fender mount starter relay, it sounds like you popped the ignition power link.
also closely check the ignition switch on the top of the column in the area above the brake pedal. it sounds like the switch separated and you need a new one.
the switch is a two piece design with a plastic upper and aluminum lower. over time the plastic separates from the aluminum piece resulting in the symptoms you are seeing.
Luko
13
Nov 24, 2017 01:05 PM
loganmick
16
Jul 11, 2015 05:09 PM
Canus
Oct 18, 2014 05:29 PM
youngAZfordguy
16
Aug 12, 2004 10:27 AM
BBiffle
Jul 22, 2003 11:19 PM
