My ignition is hotwired!!
Old Nov 22, 2017 | 09:20 PM
Luko's Avatar
Luko
So, here is the deal. This truck is kind of a mess. But without going into too many details I'll get to the point.
Someone (previous owner I presume) hotwired the starter solenoid to bypass the ignition switch. In order to start the truck: Turn key to start postion, flip the little rocker switch that bridges the terminals of the starter solenoid. The reason why this was done is because the Ignition switch in the steering column is broken. The key turns with no recoil.
I don't know how an ignition switch can break like that, but I assuming that is not an easily replaceable part...correct me if I am wrong.
I can just keep it how it is. If it is too much hassle to do otherwise, then I won't waste my time with it.
Old Nov 22, 2017 | 09:46 PM
joey2fords's Avatar
joey2fords
actually, it's a fairly easy job ... but don't confuse the ignition LOCK with the ignition SWITCH (common mistake).
the ignition switch is mounted under the dashboard, to the upper side of the steering column. the fact that there is no recoil when you let go of the key points to the switch, but keep in mind that there is a fairly common problem with the ignition switch ACTUATOR breaking.
Old Nov 22, 2017 | 09:49 PM
Robert Long's Avatar
Robert Long
Don't know why that was done, but a push button would have been a better choice if I understand this right.
Old Nov 23, 2017 | 08:03 AM
Luko's Avatar
Luko
My thoughts exactly! They went through the trouble of running the wires through the firewall to install a rocker switch.
Actuator. I believe that is what I am looking for. Thanks Joey.
If the part I am looking at is right, the actuator is synonymous with ignition lock cylinder ?
Happy Turkey DAY!!
Old Nov 23, 2017 | 08:10 AM
tjc transport's Avatar
tjc transport
i ain't rite
what year truck?
91 and older had a pot metal ignition actuator in the top of the column that broke,
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
92 and newer uses a plastic piece that is not that common to break.
the actuator connects the key cylinder to the rod that goes down through the column to the ignition switch .
Old Nov 23, 2017 | 08:21 AM
Luko's Avatar
Luko
Originally Posted by tjc transport
what year truck?
It is a 93. This is the part I was looking at.
https://shop.advanceautoparts.com/p/...Kx9EfaeMfFt654
I can turn the ignition even without the key in it. But with the key in, It will power accessory and enable the switch mod to start the engine after key is turned to start position.
Old Nov 23, 2017 | 08:49 AM
tjc transport
i ain't rite
nope, that is the key cylinder. you want the ignition actuator.
Old Nov 23, 2017 | 10:21 AM
Luko's Avatar
Luko
I think I will get a new ignition lock cylinder anyways because this one is pretty wore out.
At this point, you are directing me towards the actuator. That being said, I can still shut the engine off with the key, It just won't engage starter. Most people I have read into having to replace the actuator have issue turning off the engine. I will take a closer look at the column and see what that actuator is doing in there.
Old Nov 23, 2017 | 10:40 AM
Robert Long
It really sounds like an adjustment is in order
Old Nov 23, 2017 | 10:41 AM
Eric Fullerton's Avatar
Eric Fullerton
The downside of that is: unless you get someone to re-key the doors, you will have 2 different keys to keep up with. Even a beater truck gets locked in some neighborhoods.
Old Nov 23, 2017 | 10:44 AM
Robert Long
Loosen the two bolts on the switch and pull it up the Column toward the steering wheel tighten and try to start.
Old Nov 23, 2017 | 05:01 PM
tjc transport
i ain't rite
i have seen the actuator break both ways. 99 % of the time they break in a no start position. every once in a while though they will break in a no shut off position
Old Nov 23, 2017 | 10:52 PM
Robert Long
I have yet to be convinced anything is broken, seems more to be an adjustment.
Old Nov 24, 2017 | 01:05 PM
Luko's Avatar
Luko
Good News and Bad News
Progress has been achieved.
I was fiddling around with the cluster last night replacing some bulbs. BTW If you are upgrading to LED make sure they are short enough to fit into the socket with no interference! Anyways, in order to fully remove the cluster you have to weave out the gear position wire(only automatic trans). It goes around and underneath the start switch up to the bottom of cluster. In some way or another, I inadvertently freed something up with the ignition mechanism to where it regained its operation. But, the ring around the key was very sloppy and loose so I went to get a replacement key lock cylinder.
That is were the bad news comes in. As it turns out, the one and only key I got with the truck, does not match the door locks! Only the ignition. So, as for that, I am not sure. Locksmith? Replace drivers door lock?
loganmick
16
Jul 11, 2015 05:09 PM
'78F250351m
Mar 4, 2015 08:32 PM
Uglyknob
Jan 3, 2015 04:18 PM
Jadgarul
Apr 3, 2012 10:47 AM
jrv
May 16, 2008 08:49 PM
