Need continuity information for ignition switch
Old Oct 17, 2014 | 03:26 PM
Canus's Avatar
Canus
After a couple of years on my rebuild project (74 F100 with rebuilt 351W and AOD) today was the day to "Fire it up". When I turned the ignition switch I got nothing in the start position but when I let off the key to the run position the solenoid (ignition relay) activated and started spinning the starter. Turned off the switch and it was still cranking. Mad dash to unhook the negative battery cable to shut it down. After a few electrical tests I determined that The wire to the "I" terminal was hot with the ignition switch in the run position. Tried a different ignition switch with the same results. Hard to believe both switches are bad. Can anyone provide me with continuity information for the ignition switch so that I can determine if the switch(es) are good or bad. Can't think of anything else that could cause this problem. ALL assistance will be greatly appreciated.
Old Oct 17, 2014 | 03:51 PM
dlburch's Avatar
dlburch
Factory ignition wiring is on the far right side...
1974 Wiring Diagram
Old Oct 17, 2014 | 05:59 PM
Canus's Avatar
Canus
Thanks dlburch but I have all the wiring diagrams. Need continuity specifications for the ignition switch i.e. which contacts have continuity with the key in all positions.
Old Oct 17, 2014 | 07:27 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Here, maybe this will help?
Old Oct 17, 2014 | 08:02 PM
Canus's Avatar
Canus
Thanks 77&79F250. The middle drawing looks like what I need. My switch has 6 terminals and although your drawing appears to have only 5 my old eyes may be deceiving me. If my switch tests out OK I will have to look further to determine why the wire at the "I" terminal is not hot in the "start" position but is hot in the "run" position,
Old Oct 17, 2014 | 11:04 PM
77&79F250's Avatar
77&79F250
Yes I believe the 1st 2 pics are for the smaller 73-77.4 ignition switch and the larger milti blade bottom pic plug is for 77.5 -79.
Old Oct 18, 2014 | 02:00 PM
Canus's Avatar
Canus
Found my problem. Operator error!! Seems I had the two wires swapped on the starter relay. Had the "I" wire on the "S" terminal and the "S" wire on the "I" terminal. I had thought the "I" terminal was only "hot" when the switch was in the start position. WRONG. The wire to the "I" terminal is supplied voltage when the switch is in the run position. While running the continuity test on the switch the lights went on and I realized my mistake.
Old Oct 18, 2014 | 04:03 PM
HIO Silver's Avatar
HIO Silver
I means "ignition" (run), S means "start".
Old Oct 18, 2014 | 05:29 PM
Canus's Avatar
Canus
HIO,
I am well aware of what I and S stand for. Just had a major brain fart.
broadhek
2009 - 2014 F150
Apr 10, 2017 05:01 PM
veetwelve
Aug 31, 2012 01:33 PM
brknight
Jan 2, 2011 09:13 PM
BBiffle
Jul 22, 2003 11:19 PM
