Ignition Switch
Old Jul 21, 2003 | 11:22 PM
BBiffle's Avatar
BBiffle
Ignition Switch
I have a 89 f250 and i think my ignition switch is bad. Here is what happened. The truck starts, then the starter keeps turning. I thought that the solenoid was sticking, so i replaced it but it still does the same thing. I tested the switch wire going to the relay and when in the start position, there is 12v there. When the key is in the run position, there is 7 volts there. I think that the switch just isnt grounding the start wire after it is released. Am i right?
Thanks for your help in advance.
Beau
Old Jul 22, 2003 | 11:07 AM
RexB's Avatar
RexB
Ignition Switch
Ignition swx a probability, there's good troubleshooting in the "Engine starts,Runs & Dies according to Key positions" post from June 18th in the "Electrical Wiring/. ." forum section.
Old Jul 22, 2003 | 05:26 PM
rickthefix's Avatar
rickthefix
Ignition Switch
Could your bendix on the starter be sticking?
Old Jul 22, 2003 | 11:19 PM
BBiffle's Avatar
BBiffle
Ignition Switch
Well, i changed the switch and it works fine, thanks for your help.
