Sunpro Super Tach 2
Old Jan 28, 2017 | 05:22 PM
XLTRat's Avatar
XLTRat
Sunpro Super Tach 2
Just installed a Sunpro Super Tach 2 in my 72 XLT. With the ignition switch on and motor not running it reads 1000 rpm. Crank it up it reads 1500 rpm at idle which I know is incorrect. The switch is on 8 cylinder. Green wire on negative side of coil. Black ground. Red to switched 12v. Any suggetstions? Bad tach?
Old Jan 28, 2017 | 09:35 PM
Freightrain's Avatar
Freightrain
Sounds like a bad tach, or the needle needs adjusting. Doubt you can adjust the needle, so I would take it back and get a new one.
Old Jan 28, 2017 | 11:46 PM
orich's Avatar
orich
2x with a bad tach, as your not the first guy to come here with a bad tach issues.
Yup return it.
Orich
Old Jan 29, 2017 | 07:38 AM
XLTRat's Avatar
XLTRat
Thanks guys. That's what I was thinking too.
Old Jan 29, 2017 | 07:43 AM
HIO Silver's Avatar
HIO Silver
Try resetting the switch to see if it "wakes up" to show the correct rpms.
Old Jan 29, 2017 | 04:39 PM
jowilker's Avatar
jowilker
It has been a long time, but if I recall there are 3 wires. Would you share with us which by color is connected to where.
I don't want to discount the other guys replys but sometimes we can get the wiring wrong. Let's make sure on that 1st.
John
Old Jan 29, 2017 | 05:40 PM
XLTRat's Avatar
XLTRat
Tried resetting the switch. Didn't work. Red to switched 12v power. Black to ground. Green to neg side of coil. White to instrument lights. Tried it on my Jeep. Didn't work on it either. Both have stock ignition. So I'm definately thinking the tach is no good.
Old Jan 29, 2017 | 06:46 PM
HIO Silver's Avatar
HIO Silver
Yep. 'Time to stick a fork in it.
Old Jan 30, 2017 | 05:37 PM
JEFFFAFA's Avatar
JEFFFAFA
.....It's done.
Rusty_S
Sep 8, 2015 01:08 PM
79boston150
May 6, 2009 06:43 PM
jas2187
Nov 3, 2004 07:37 PM
Trav460
Electrical Systems/Wiring
Feb 18, 2004 11:23 PM
wally2117
Jul 16, 2002 11:35 PM
