Tach problems... imagine that
Old May 6, 2009 | 05:57 PM
79boston150's Avatar
79boston150
So i finished hooking up my autometer tach on my 91 f150 302... and to the best of my knowledge it's hooked up properly but there is a slight problem. I am getting off the wall tach readings. I bought this aftermarket tach because i believed the cluster tach to be messed up (reading 3500 rpm at start up and 3000 when the engine is off). Now when i started her up my "new" tach is reading 2400 rpm. I can tell just by the sound that its definetly not at 2400... is there something else that could be causing the false reading? and before anyone says anything i do have the tach set for the v8 setting.. only thing that i could come up with would be a possible faulty reading from the ignition coil? any help you guys could give me would be great... thanks
Old May 6, 2009 | 06:40 PM
frederic's Avatar
frederic
most aftermarket tachs have a switch to select the number of cylinders. Did you set that properly?
Old May 6, 2009 | 06:43 PM
Virto's Avatar
Virto
Lol, well according to his first post, he does have it set to 8.
You ran a nice new wire to the tach test on the coil, right? Nothing recycled or kinked?
blifsey
Jan 13, 2025 12:46 AM
bigham25
1983 - 2012 Ranger & B-Series
Apr 10, 2014 10:09 PM
03trueblue
Aug 26, 2012 09:30 AM
Old Hickory
Feb 26, 2011 08:39 AM
jdhford67
Oct 11, 2008 03:16 PM
