Injectors for towing?
Old Jan 28, 2017 | 11:42 AM
  #31
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by andym
This was in the back of my mind too. I sorta regret going with the S&B cold air intake, but it seems to work well enough. Should I go with the same 6637 setup that most people here seem to like?
If you decide to sell that S&B, keep me in mind. Although you should keep it and be happy you bought the right one the first time around.
Old Jan 28, 2017 | 11:49 AM
  #32
Tugly's Avatar
Tugly
Keep the S&B - that's what I run with my 160/100s, T500, and 38R. I identify with SRBF150 - that's how I feel with my setup. I think I haze more than the 80% nozzles with cold air/engine/fuel.
Old Jan 28, 2017 | 11:50 AM
  #33
Benjaminesh's Avatar
Benjaminesh
Wow. $2400 for a set of injectors.
What do you think I can get for a kidney? I know my liver isn't worth ****...
OK guys... I need help deciding what to do here.
I have a perfectly functional set of stock injectors with roughly 180,000 miles on them. I bought the truck at 140,000 from the original owner but I have no maintenance records and I don't know how often the oil was changed. It was bone stock when I got it, except for a K&N filter that was nearly plugged solid. I'm pretty sure I hear one injector a little more than the others on the driver's side when its cold. When its warmed up it sounds healthy.
I've heard that the max reasonable lifetime on a set is 300k. Is that about right? At the very least, since I'm going to be into this far anyway, I would like to change the o-rings this spring.
So the big question is.... what would you do:
- Would you just put o-rings on stock injectors and plan on replacing them in 3-4 years?
- Would you attempt to rebuild the injectors to stock specs yourself?
- Would you bite the bullet now, while everything is apart, and spend $2400 on a new set of 160/80 injectors that might lower EGT's by 100 or 150 on grades?
Keep in mind that my goal is to live full-time in my RV for the next few years starting this fall, while traveling around the US.
And since you asked,
Re-oring the stock injectors, possibly replacing the glow plugs while you have them out anyway.
And then work on flowing more air, get a 38R if your able to, If not simply rebuild your turbo with a 360 thrust bearing and a billet wheel. Simply increasing your airflow will drop EGT's a bunch.
Old Jan 28, 2017 | 12:17 PM
  #34
andym's Avatar
andym
I think I'm going to hold off on doing a turbo right now. I would have to go with a 38R because I live in CA, at least right now. I'm probably going to title and register vehicles in Florida eventually, but I'm not sure I'm enough of a speed freak to spend $3200 on T4. I was planning on doing the SPT rebuild kit and compressor wheel. I'm thinking about having them balance the assembly for me too. Glow plugs are on the way.
I read a post a few years ago that a cold air intake is basically useless on these trucks because of the intercooler. I immediately felt stupid for ordering it and have regretted it since. I'm glad it actually turned out to be a good decision. It is a really well-made kit and works great.
Old Jan 28, 2017 | 01:21 PM
  #35
Dan V's Avatar
Dan V
What if I rebuilt my injectors with 80% nozzles? They are 155cc, right? Would I be able to get away without flow testing them?
No. They still flow 160cc per 1000 strokes. The % relates to the size of the nozzle hole...above stock.
Old Jan 29, 2017 | 07:33 PM
  #36
Stewart_H's Avatar
Stewart_H
I'm putting in a built 4R100 from BTS or JW this spring.
Just saw this thread and I didn't read past the post I quoted, so if this was already suggested, ignore it Andy. But if it were me (and this is something I still want to do) I'd put AC codes with 100% nozzles in the Ex, get the PCM flashed for them (so if you have to remove the chip for any reason you can still pass CA smog), and upgrade the tunes on your Hydra.
While I have some fairly hopped up sticks in my truck, and it tows heavy, it mainly does it locally. Our Ex is our main tow pig for vacations and such and I have always wanted to swap to a set of AC's.
I had a stock set of AC's (stock nozzle size) on my old F250 (now my daughters) and that things runs fantastic, pulls hard, and tows like its nothing. Joe (@Gaugepro) also has AC's (can't remember the nozzle size) in his wife's Ex and he likes them too.
One good thing about the AC's (with stock nozzles, not 80% or 100%) is they are an OEM injector, so they can be purchased from just about anywhere that sells parts (think: Autozone or O'Reilly's), so if you happen to be traveling and something happened (rare), you would have many options.
Hey, when and if you go with a JW built trans, are you gonna drive down?
Stewart
Old Jan 29, 2017 | 10:03 PM
  #37
Sous's Avatar
Sous
FTE Emeritus
Here is a question that I have not seen before, and it is not too far of the beaten path from what the OP is gaining knowledge about.
Say someone upgrades to 160/80 injectors and their tuning is changed on the Hydra to allow for great towing and daily driving. Then along the road they have a failure on one of the 160/80 injectors for some reason that is not important to the question. Is it possible to put a stock AC (160/0) from a local store into the vehicle and run it with the other 7 injectors still 160/80, or would this be a very bad thing and cause more damage than waiting a week or two for a new injector from their supplier?
Old Jan 29, 2017 | 11:04 PM
  #38
The Brad's Avatar
The Brad
It would probably run with a slight miss or lower power on the cylinder with the 0% nozzle, but it would get you by until the 80% injector was fixed. Then send the stock one in to get renozzled. In all reality, I think any injector issues on remans will show up sooner, rather than later.
Old Jan 29, 2017 | 11:10 PM
  #39
Tugly's Avatar
Tugly
It would almost be the same as unplugging the offending injector. Spend that kind of money when you can simulate the effect for free? I'd get the truck home and park it until the parts came in... but I have options.
Old Jan 30, 2017 | 01:14 PM
  #40
andym's Avatar
andym
I really like the idea of using AC injectors with 80% or 100% nozzles. What about passing smog with this setup? From what I've read, a well-tuned set of single shots, even with larger nozzles, should be able to pass the smoke test, right?
Stewart
I'm leaning that way. I am still questioning the wisdom of swapping transmissions by myself in the driveway. Literally every single part on this truck is so heavy that I don't know how I'd do it. The transmission jack that Harbor Freight sells is so small would look like an ant trying to balance a cheese doodle on its back. I just don't see it ending in anything other than catastrophe. I've swapped engines and transmissions before so I have an idea of what it takes.
Wanna make a road trip?
Old Jan 30, 2017 | 01:22 PM
  #41
andym's Avatar
andym
If I had a situation where I absolutely couldn't just kick back and spend some time in Podunk while waiting for an injector to show up, I would just keep a spare. But my travel plans aren't usually that firm and an extra week somewhere wouldn't kill me.
It's an interesting discussion though. In a gas motor a lean mixture in one cylinder will cause a lot of problems, like burned valves and lots of carbon build up. Would a lean mixture in one cylinder in a diesel cause any problems?
Old Jan 30, 2017 | 01:31 PM
  #42
Stewart_H's Avatar
Stewart_H
Yup, it's all in the tuning.
A tune can make a set of stock injectors haze at idle like a set of B codes on an 11 second truck, or they can make a set of A code 225/100's behave like they are stock at idle.
Very heavy and cumbersome.
We pulled the trans in my sons truck a few years back in order to send it to John and have him rebuild it. There was three of us and damn was it hairy a couple times.
If you're by yourself, I would make sure to have at least a trans jack and a floor jack to assist with positioning.
This one 450 lb. Low Lift Transmission Jack along with a floor jack looks like it would do.
Yup, if you choose JW and the timing of the trip works, I would most definitly be interested in a road trip. I've enjoyed all my previous trips down to Johns place.
Stewart
Old Jan 30, 2017 | 03:09 PM
  #43
The Brad's Avatar
The Brad
When I replaced my trans, I used an atv jack with a 3'x3' plywood and sandbags. The sandbags conformed to the trans and allowed me to make adjustments to line it up. I did the R&R alone and it worked great.
I had no problems passing smog with 200/80s and neutered tuning flashed to my pcm. I can floor it all day long with zero smoke.
Old Jan 30, 2017 | 03:24 PM
  #44
jhl3's Avatar
jhl3
Who is your tune writer?
Old Jan 30, 2017 | 04:22 PM
  #45
The Brad's Avatar
The Brad
Jody at DP Tuner.
