Best Injectors
Old Jan 26, 2017 | 03:35 AM
Tugly's Avatar
Tugly
ADs and AEs (stock on our truck) are about 140 CCs. AC 160s are stock on the IH DT466. Our 7.3L (IH T444E block) shares the same injector design with the DT466, so we're just grabbing off their shelf for more HP.
Pocket really nailed it with this explanation of nozzles on another thread:
Originally Posted by Pocket
"Better" depends on how the truck will be used. I'll try to sum up the difference a short and concisely as possible:
In a nutshell, a larger nozzle becomes more efficient - compared to a smaller nozzle - as the RPM's increase. But on the flip side, the larger nozzles are in essence less efficient at lower RPM's.
It boils down to fuel-per-time. Yes larger nozzles don't atomize as well, but as the RPM's increase significantly, the fuel-per-time capabilities of larger nozzles overcomes the differences in atomization. That's why a larger nozzle can run cleaner with less smoke and much lower EGT's at say over 3,000 RPM compared to a smaller/stock nozzle.
But that comes at a cost to lower RPM efficiency, where larger nozzles haze easier and have a much more difficult time dialing in the idle quality. Go really huge on nozzle size and you can actually see a decrease in fuel economy, especially at cruising RPM's.
So what are you accomplishing with a change in nozzle size? Simple. You're re-positioning the effective RPM range that you'll be utilizing.
Do a lot of heavy towing? Well you probably spend more time at higher RPM's, so moving up in nozzle size can greatly increase your towing capabilities while simultaneously decreasing smoke and EGT's. This of course assumes that tuning is done correctly.
Your truck never tows and you just want to increase fuel economy? Stick with a stock AC injector with stock nozzles. Keep the efficiency at the lower RPM range where the truck will live most of its life.
Old Jan 26, 2017 | 08:46 AM
lpzd's Avatar
lpzd
Not all versions of the 466 had AC injectors if fact I think only one did and pretty sure they had different nozzles . The AC was used in the t444e "high torque " but never in a Ford .
not tying to be argumentative just don't want anyone heading to diesel bone yard thinking they are going to find performance injectors .
Old Jan 27, 2017 | 07:34 AM
Tugly's Avatar
Tugly
I'm always open for more input - no snot bubbles emitted here.
Looking this up again, the AC 160 has the same nozzle as our AD/AE. The T444E HO (High Output) does use the AC 160, but the DT466E uses the B-series injectors - the interweb lied to me before.
Old Jan 27, 2017 | 08:43 AM
lpzd's Avatar
lpzd
dDT466 in mid 90's had single shot Acodes with 5hole nozzle , but only 1 or 2 versions. yeah AC uses same 7 hole nozzle as all the powerstrokes.
Fuzzynuts
13
Sep 17, 2017 08:55 PM
ricg
Dec 30, 2008 10:39 AM
Boss300
16
Dec 10, 2008 04:18 PM
my79f
Oct 23, 2007 07:06 PM
97REDPSD
Apr 10, 2007 04:07 PM
