od light flashing
Old Feb 6, 2017 | 11:53 AM
  #31
finn12's Avatar
finn12
I have the cd. I did what you said about accelerator pedal and you were right. It appears to work fine.I took some pictures of the tests. I am getting no codes and eratic shifting.it seems like torque converter lock up all the time. i can send what every pics you need just tell me and I will take pics of the screen .As i drive the od is flashing after 2nd gear,it drift .in and out of gears.I does shift in to overdrive.
Old Feb 24, 2017 | 07:53 PM
  #32
finn12's Avatar
finn12
It turned out to be the instrument cluster had a short in the speedometer! I need to get it rebuilt. Any body you can recommend?
Old Feb 24, 2017 | 08:00 PM
  #33
madpogue's Avatar
madpogue
Just get a PSOM from a junkyard truck. If you find a truck that had the same size tires as yours, you won't even need to calibrate it.
Old Feb 25, 2017 | 01:19 PM
  #34
finn12's Avatar
finn12
I have one from a junkyard but the mileage is 375000 truck runs fine. my original odometer reads. 121,000. So i want to get my original repaired. So if I ever sell it has the correct numbers.
Amicus
Mar 31, 2017 11:53 AM
Mark Alligood
May 22, 2012 09:05 PM
rscamaro305
34
Oct 29, 2011 03:28 PM
woodduck17
Jul 29, 2009 10:48 AM
strokeman
Aug 27, 2003 10:36 AM
