Group 31 install
Old Jan 21, 2017 | 08:36 AM
IDIoit's Avatar
IDIoit
Group 31 install
just bought a set of group 31s for the 01.
the stock battery trays are going to have to be modified/deleted in order to run them.
not a big problem minus the fact that I may have to change the window washer reservoir.
anyone have a set of these batteries in the stock location?
this is on the list to do today, if you got em, please leave a pic!
Old Jan 21, 2017 | 08:47 AM
Rikster-7700's Avatar
Rikster-7700
I seem to recall another recent thread with something similar, but they were looking to mount them between the frame rails or something along those lines. What made you decide to change to group 31's?
Old Jan 21, 2017 | 08:48 AM
IDIoit's Avatar
IDIoit
I needed batteries, and the stock batteries were 160 a piece, with I believe 700 CCA's
I got these for 110 a piece with a 5 year warranty. and have 1000 cca's a piece
, I fricken hate lead post batteries!
Old Jan 21, 2017 | 08:50 AM
Tugly's Avatar
Tugly
There goes the snout for the stock air intake.
Old Jan 21, 2017 | 08:55 AM
IDIoit's Avatar
IDIoit
yes sir, a custom cowl hood is on the list.
Old Jan 21, 2017 | 09:54 AM
AllaboutMPG's Avatar
AllaboutMPG
Nice!!! Pictures if you please Sir
Old Jan 21, 2017 | 10:07 AM
IDIoit's Avatar
IDIoit
heres my last one,
im on the hunt for a 1958 custom 500 style x2
Old Jan 21, 2017 | 10:59 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
That is cool looking, I like it. Keep us up to date on your progress and good for you for breaking out of the box a bit.
Old Jan 21, 2017 | 11:09 AM
AllaboutMPG
let's in enough air for a 7.3? how do you hook it to the filter or is it just air under the hood?
Like the look and the bumper. You make that too?
Old Jan 21, 2017 | 11:27 AM
IDIoit's Avatar
IDIoit
I came out of the preverbal box in 76, and stayed out except for spawn practice
hood will be another thread, but yes I made it all.
I have a build thread for the 01 if youre interested.
https://www.ford-trucks.com/forums/1...4wd-build.html
today is about getting batteries installed!
Old Jan 21, 2017 | 12:18 PM
AllaboutMPG
Oh, I've been following the other thread with enthusiasm. A little jealous of your ability and really enjoying watching it come together.
Old Jan 21, 2017 | 03:36 PM
IDIoit's Avatar
IDIoit
well took me longer than I thought, calling it a day short today, gonna spend the rest of the day with the kiddos
minor modifications to the truck itself
cut the existing tab for the inside battery support off, and dropped it down 3/4-1"
welded it back on.
used 1x1 angle and made a box,
added some 2" strap In the middle for the inside support.
then took some 4" strap and made a outside bracket to the existing mounts on the left side support.
I notched a little corner in the sheet metal so the battery wouldn't rub on it.
I did get the battery strap bent 1" metal strap, but I have not drilled the holes for the bolts.
charge pipe has sufficient room also,
and more than enough room from the top of the lugs to the hood.
if I get shop time tomorrow, ill do the pass side, which will be almost the same
except for it will be easier after I cut up the support mount.
don't have to do jack crap for the washer reservoir except for to pull it for welding.
60 bucks in steel
220 for batteries
a few hours makin it work.
well worth it.
Old Jan 21, 2017 | 10:03 PM
Firefighter 1406's Avatar
Firefighter 1406
Very nice. I have to say that I wish I had your fabrication skills. I kind hold my own but you definitely dive into things I would only dream of doing.
Old Jan 22, 2017 | 02:37 PM
IDIoit's Avatar
IDIoit
and its complete, hold downs and all.
I didn't get as detailed pics of this side, well because its the same process, just flipped.
came out decent. and I will add to the drivers side to hold my air filter the next time I work on it.
TooManyToys.
Dec 13, 2017 07:28 PM
bushman31
May 10, 2010 11:07 AM
preppypyro
32
Jan 3, 2009 09:56 PM
wecsubloc
Jul 8, 2008 11:22 PM
Old Speed
Jun 19, 2005 12:21 PM
