question about 6637
Old Jul 8, 2008 | 08:49 AM
wecsubloc's Avatar
wecsubloc
question about 6637
Is ther any way you can installing the 6637 w/o removing stock battery box?Thank you very much!
Billy
Old Jul 8, 2008 | 08:54 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Jist like this. Yes you can. No cutting, just take the old box off and install the 6637.
Old Jul 8, 2008 | 08:55 AM
superduty4x4's Avatar
superduty4x4
Yep, it's easy. All you need to remove is the stock airbox upper and lower halves. Once you get the stock lid off and pull the filter out, you'll see two screws in the bottom of the airbox. Then there are two more behind the battery. Pull the IAT out of the lower airbox half and you're done. When you install the 6637 zip-tie the IAT sensor to the brake lines under the master cylinder and you're set for your 6637 install. You may want to take a Dremel and do some cutting- there are some sharp edges in there. I was going to cut my stock battery tray up (the part under the stock airbox), but I'd like to keep it one piece so I can Ebay it when I get around to building a cold air box and custom battery tray.
Old Jul 8, 2008 | 08:50 PM
F250_'s Avatar
F250_
Another "yes" vote here. I have to sort of tilt mine up at an angle so the hood will close, but it fits.
Old Jul 8, 2008 | 08:59 PM
hucka1a's Avatar
hucka1a
What Chase said. Don't forget to get a filter cover from Pete.
Old Jul 8, 2008 | 09:05 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Ya you defiantly cant forget that!!
Old Jul 8, 2008 | 09:16 PM
jdecker88's Avatar
jdecker88
Thats how mine sits
Old Jul 8, 2008 | 11:22 PM
randomhero1172's Avatar
randomhero1172
I gutted the crap out of my box. Probably no performance gain though
Winmagbar
Ford Truck Parts for Sale
Mar 21, 2016 10:42 PM
kbarbee95
20
Aug 6, 2015 05:28 PM
Kevinr92
40
Sep 4, 2014 08:49 AM
snakedoc
17
Oct 21, 2013 05:40 PM
nrskel78
Oct 26, 2009 01:15 AM
