Sponsored by: Real Truck
Remote Start Wiring Question
Old Jan 19, 2017 | 10:31 PM
reptar0077's Avatar
reptar0077
So!! Almost freaking done with my remote start installation.
On a 2003 F-250 5.4 XLT
My question please!!
Do I need to kill the factory Key less door entry locks??
Or can I simply install both remotes (Remote Start & Alarm WITH Factory Key less Entry? )
EDIT: Appears that Factory NON Alarm only keyless entry does work side by side with aftermarket remote start.
https://www.tacomaworld.com/threads/...eyless.113870/
Also while I'm at it, the relay for the starter, that goes between the starting solenoid & the starter correct?
EDIT: Found it, wiring relay goes between the ignition wiring between the starter wire (Green & Lt green red.) Relay wire goes to alarm unit the "starter interrupt."
Thank you!! Probably going to do a write up when done, seeing as how I've pieced lots of helpful pictures wiring & tips.
Old Jan 20, 2017 | 03:59 AM
Just Strokin's Avatar
Just Strokin
Glad you were able to find out that both keyless door lock remotes still work as they should since they are independent of each other on how they generate the signal to actuate the locks.
I never installed the interrupt relay.
Old Jan 20, 2017 | 08:43 PM
reptar0077's Avatar
reptar0077
You never installed one for your remote start? It worked without one?
rocketman2440
16
Feb 4, 2011 10:20 PM
moose_j9
Dec 16, 2010 11:42 PM
gradynh
2009 - 2014 F150
Aug 21, 2009 04:31 PM
ncage1974
1997 - 2003 F150
Dec 9, 2006 03:51 PM
Fordtrk26
1978 - 1996 Big Bronco
Jan 31, 2006 10:58 AM
