LIFT
Old Jan 16, 2017 | 09:14 AM
GASPIG88's Avatar
GASPIG88
LIFT
my 86 f250 front springs a saggy.
if i install a lift... would i be money ahead to swap in a solid axle?
Old Jan 16, 2017 | 09:19 AM
rowdyredneck's Avatar
rowdyredneck
If you do a solid axle swap you'll have to install different springs as well since the TTB springs will ride extremely harsh with a solid axle. Dana 60s aren't cheap and are getting harder to find too. They're still out there but you can expect to pay at least $700 for one.
Old Jan 16, 2017 | 11:24 AM
Franklin2's Avatar
Franklin2
Everyone hates the factory springs on the f250 ttb's. I have to agree, they just don't look right, but that's the way the factory designed them, arched up in the center.
Old Jan 16, 2017 | 11:36 AM
Nothing Special's Avatar
Nothing Special
To elaborate on what Franklin2 said, how do you know that your springs are sagging? If it's because they have negative arch and it doesn't look like you have much up-travel available, that's normal.
If your springs are really sagged your front tires will be tipped in at the top. And note that you need to check that after the truck was moved forward. If you back up it will tip the top of the front tires in too, but that's normal.
Yes, the F-250 TTB is a quirky animal.
Old Jan 16, 2017 | 01:42 PM
GASPIG88's Avatar
GASPIG88
with a lift kit what kind of articulation and travel am i looking at? i want the truck to take the bumps of logs rocks and tractor ruts not my keester
Old Jan 16, 2017 | 01:48 PM
GASPIG88's Avatar
GASPIG88
i have all the late 70's coils suspension stuff laying around when i was thinking of sas'ing my old bronco. but the TTB on it does me proud.
so i would be swappin in a D44HD (8lug 44) with the radius arms, and 4 inch springs.
i have all of those parts... but for a deer lease/farm and ranch truck with good abilities off road. just a good all around truck.
the speed bump here is lift? or swap? comes down to the money really bang for the buck... i dont mind workin on the old hag to keep her around lol
plenty of tools for the job, i can fab what i cant find or buy.
welders, lathes, drill presses, etc... full shop. just dont want to torch something if it will meet the demands.
someone on another forum said if i put a locker in the D50 and a 4 inch lift i will be happy.
Old Jan 16, 2017 | 01:51 PM
GASPIG88's Avatar
GASPIG88
keep in mind... it does not snow here... i am in south east tx.
only real obstacle on freshly cleared land is MUD and logs and rocks.
no mountains... none of that.
Old Jan 16, 2017 | 03:06 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Lifting a TTB front end requires drop pivots and pitman arm to keep steering and alignment geometry within limits.
Sky now makes a RSK that works with 250's and uses ToughCountry 20852 drop brackets.
Some welding is required, but not full boxing of the horns.
*FORD FS-ROB 002 NoPanHard*
As has been said, TTB front ends do not articulate well and since the springs hold the front end in place, bushings take a beating as it twists.
Old Jan 16, 2017 | 04:06 PM
Nothing Special
Most people (me included) think that you can't get what you are looking for out of an F-250 leaf spring TTB suspension. However, having said that I have to admit that I've never driven a lifted leaf sprung TTB.
There is someone on this board (sorry, I'm not remembering his screen name right off) who claims to have had success getting good travel and ride out of a lifted leaf spring TTB. If you can find him (I think he's mostly on the '87-'96 forum) he might be able to help you better than I can.
edit: I was thinking about '89F2urd. I've run into him in a few different threads about lifting F-250s. He seems to know his stuff.
Old Jan 16, 2017 | 04:23 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
BBF385 discusses the lift I mentioned.
The thread "want to raise front to level 89 f250 4x4' is in the '87-96 forum.
If you read the link it says you can get 2.5" out of it.
If you want more you are better off with a sas
Dan Patterson
Apr 7, 2019 10:44 AM
79OldBone
Jul 14, 2012 05:51 PM
1980 Ford F-250
Apr 12, 2011 05:21 PM
Country_boy_2007
66
Nov 23, 2010 09:09 PM
