Solid axle swap adds lift: True or False?
I got a 97 F350 Powerstroke parts truck to put the axles under my F250. I know the rear has taller blocks then my F250 but I just bought new front springs last year and would like to use them. The spring company said the code I gave them was for the heavy duty springs that F350s usually use but that's what my truck had for a code.
These should work fine with the solid axle and the F350 blocks in the rear correct? Does the way the leaf spring sit on the solid axle add some lift to the truck? Is that was does it?
The F350s have a bigger block then the F250 in the rear so it definitely sits a couple inches higher. I just wanted to make sure the new front springs will work fine.
My brand new springs sag with that TTB also. Does that system make them sag? Will the solid axle make them have a positive arch again?
on
Do not use the TTB front springs on a solide D60! I tried it and it sucked. Unless you want to feel every pebble you run over and like getting thrown around in the cab. I tried it for 5 months or so, until I had time to put the F350 spings in the front. Rides so much better. The D60 and springs came out of a 91 F350 standard cab with 460 gasser. I also put some SD rear springs in the back prior to the swap. Rides pretty good.
Also if you have the parts F350 truck there, swap the pitman arm from the box. They are different from the 250 one and you end up with a wider turning radius with the 250 pitman arm. I bought a new 350 one and it is slightly longer and little different shape. You will probably be better swapping steering boxes because those pitman arms sometimes do not come off very well. I think I will need to cut mine off to do the swap, it wouldn't pull off.
on
I cant agree with this more!!! I had a 4" lift spring on the front when I did my conversion. The solid axle only lifted the front about 3/4". It would bruise my ribs if I ran over a quarter at 25mph! HATED driving the truck. Switched to the two leaf from the donor 350 and installed the Sky RSK. Rides like a Cadillac now and sits level.
caliaviation
1999 to 2016 Super Duty
09-08-2013 05:28 AM
1980 Ford F-250
04-12-2011 05:21 PM
