Starter motor compatibility question
Old Jan 15, 2017 | 06:47 PM
Adam Reeve's Avatar
Adam Reeve
Hello all,
I have a quick question for you.
Before i get fried for not doing my readings...I have done some research in different starter motor topics on this forum; rat trap/clapper, external solenoid, auto and manual starters and flywheel/flex plate configurations..
Basically my scenario is this.
My 85 302 manual f100 has been a pain the bum to start.. slow cranking, seems like the battery is dying, hot wires from relay, puffs of smoke etc..
I started with reading through these forums and tried recommended fault finding...
I replaced the battery, replaced the starter relay, checked terminals and leads for corrosion/breaks.. replaced all cables from battery-starter relay-starter motor-ground cables... to find that none has resolved the issue..
Finally i took out the started motor yesterday to find that the housing where the starter gear sits has snapped in half..
Before i go any buy a new clapper, I have a second hand working XF falcon 250 starter that came out of an auto configuration given to me last night.
I haven't done any measurements to the starter motor yet... I will tonight once I knock off work..
Does anyone know off the top off their head if the starter motor will fit (obviously I will need to do some minor wiring changes for the solenoid), but will i need to space the motor out a few mm... or will it not work at all do to "potential" flywheel/flex plate teeth mix match.
Hopefully you can understand my jargon.
thanks in advance.
adam
Old Jan 15, 2017 | 07:37 PM
ctubutis's Avatar
ctubutis
Didn't they phase out the F100 in something around 1983?
Old Jan 15, 2017 | 07:52 PM
Franklin2's Avatar
Franklin2
I looked, he is from Australia. I am not sure we are going to be able to help very much, Ford used different engines and configured their vehicles differently over there. I am not even sure what Falcon looks like and what engines it had.
Old Jan 15, 2017 | 08:10 PM
Adam Reeve's Avatar
Adam Reeve
haha.. no worries..
Thanks anyway.. I'll put on my experimental hat when I get home and let you know the outcome..
If it doesn't help you yanks, it may help someone else.
Cheers
Old Jan 15, 2017 | 08:19 PM
Gary Lewis's Avatar
Gary Lewis
This page on my web site shows the starters used in the US for these trucks: Starters - ???Gary's Garagemahal. Note that the 300 six and the Windsor 8's use a different starter for a manual transmission than an automatic. I don't have any way of knowing for an Aussie 250, but it doesn't look good.
Old Jan 15, 2017 | 08:32 PM
Adam Reeve's Avatar
Adam Reeve
Gary, I have your website bookmarked already Has helped me out heaps.
Looks as though the 250 flex plate is 160T and the 302W flywheel is 164T..
So that may cause some binding I'd imagine. Close however
Old Jan 15, 2017 | 08:36 PM
Gary Lewis's Avatar
Gary Lewis
Close, but no cigar. ;-)
Glad the site helps. And, by the way, the starter page is new, just for you.
Old Jan 15, 2017 | 09:07 PM
Adam Reeve's Avatar
Adam Reeve
Ahh, you are a good man..
I have been very upset the last couple of work days when the site was down.. I actually had to do work!!
Old Jan 15, 2017 | 09:20 PM
Gary Lewis's Avatar
Gary Lewis
Sorry about that!
Old Jan 16, 2017 | 06:28 AM
Tarheel Blue's Avatar
Tarheel Blue
Adam,
Check in over at the FordSix.com site. Lots of the folks on there know about the "down under" Fords!
Old Jan 16, 2017 | 09:08 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
"Down Under" trucks could have the 351C (Cleveland) that was only installed in US/Canada 1970/74 Ford/Merc Passenger Cars & Ford Rancheros.
351C A/T starter is different than M/T starter. Flywheel ring gear has 164 teeth.
Old Jan 16, 2017 | 09:11 PM
Gary Lewis's Avatar
Gary Lewis
He has a 302, Bill. But, now that I think about it, they had a 302 Cleveland, and I don't have any info on what starters they took.
Old Jan 18, 2017 | 02:56 PM
Adam Reeve's Avatar
Adam Reeve
hey guys...
as expected.. no luck with the 250 x flow starter.
I ended up ordering a new one off ebay.
From my understandings.. 289,302w, 302c, 351w and 351c manuals all take the same starter.. autos are slightly different as mentioned above.. 164T for a manual and 157T for autos with different protrude lengths of nose and gear
hotrodharley84
May 21, 2013 12:17 PM
zombiehunter
Jul 9, 2012 07:08 AM
2kf150
1997 - 2003 F150
Aug 22, 2004 08:08 AM
LunaI
Jan 16, 2004 05:30 PM
jonathan219
May 17, 2002 01:54 AM
