302 starter help..
Old Jul 8, 2012 | 04:10 PM
zombiehunter's Avatar
zombiehunter
302 starter help..
ok so i have a 91 mustang motor, with a brand new stock replacement flywheel, luk clutch and pressureplate. the engine is mated to a t10 topload 4 speed from a 67 fairlane. i ordered a starter for the fairlane, and it worked a couple times and now when i start it the starter is staying engaged sometimes. do i have the wrong starter for this application or is something else off. i also DO have the aluminum spacer plate between motor and trans because i know that makes a difference. any and all input is greatly appreciated
Old Jul 8, 2012 | 09:04 PM
Beanscoot's Avatar
Beanscoot
It sounds like you do have the wrong starter motor. Did you tell the parts man that it was for a 1967 Fairlane with a manual transmission?
The automatic starters have a different snout which will cause the drive to project too far, resulting in the chronic engagement.
Old Jul 9, 2012 | 07:08 AM
zombiehunter
yeah i ordered it myself on rockauto. i got froggy last night and tried a fox mustang starter and it works fine. im not sure what bellhousing i have, it does not appear to be a fairlane one. and i cant see any numbers except where "ford" is cast into it. its aluminum though. i dont know i just hope this starter will last. only time will tell. thanks for the input as well.
xXANBXx
Oct 29, 2018 06:50 PM
papabills54
17
May 7, 2015 05:09 AM
Tim J
Sep 13, 2014 03:58 PM
dirtybroncoii
Bronco II
19
Jul 21, 2009 03:59 PM
6fifty_f1fifty
May 28, 2009 07:54 AM
