Sponsored by: Kumho
steering sticking
Old Jan 7, 2017 | 11:36 PM
therigwelder's Avatar
therigwelder
steering sticking
i just picked up a 96 f250 4x4.I was told it had a brand new steering gear put in but when you steer,it sticks and is tight to the right and left.if i turn to the left there is no self return you have to manual steer it back to center and the same if you turn to the right.what is wrong?
Old Apr 18, 2017 | 08:57 PM
lildobr's Avatar
lildobr
ok I tell you
The person who worked on it has it adjusted to tight you.If you look at the steering box you will see a little stud with a slot for a screwdriver to go in and a lock-nut Loosen the lock-nut and turn the screw stud to the left.Then with one hand turn the steering shaft back and fourth slightly until you feel a little bit of play like about two sixteenths and tighten lock-nut while holding stud so it doesn't turn and test drive.
Old Jun 2, 2017 | 05:12 AM
mark a.'s Avatar
mark a.
Were the ball joints adjusted right ? What about the axle shaft U joints ? If one freezes up it can do the same thing.
Old Jun 3, 2017 | 06:10 PM
Laggy's Avatar
Laggy
Whats your caster look like?
BillyBob69
23
Aug 12, 2016 02:49 PM
01raptor
Mar 28, 2012 05:01 PM
staysbroken
Apr 24, 2006 04:16 AM
greybullit
1978 - 1996 Big Bronco
Jan 23, 2006 02:12 PM
Rackpatrol
General Automotive Discussion
Mar 4, 2004 08:54 PM
