General Automotive Discussion
Power Steering Preload
Old Mar 3, 2004 | 09:23 PM
Rackpatrol's Avatar
Rackpatrol
HOW IMPORTANT IS THE PRE LOAD SETTING ON POWER STEERING. Can any one tell me if I can get close enough on the adjustment without taking the unit out of my truck. I had alot of loose play in my steering wheel,and my truck would wander from side to side. I replaced all the ball joints and steering joints because they were all loose. 247,000 miles. Any way this helped alot but it did not totaly fix the wander. So I adjusted the preload one full turn tighter (clockwise). This made a world of differance. I would like to turn it a little more but I dont know how much is to much. Any sugestions THANKS
Old Mar 4, 2004 | 09:56 AM
Big Orn's Avatar
Big Orn
If it's a Ford - say 70's - there's a worm gear that can become worn in the middle section. Tightening it up to remove play in that area may make it harder to turn further up or down the shaft (right or left steering). You would need to put the front axles on stands and see if it will lock up or not. It could be dangerous to tighten too much.
Old Mar 4, 2004 | 03:57 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Orn is correct in taking wear into account. I've seen methods involving raising the vehicle, tightening the box a bit, and checking the torque (with a wrench) required to move the steering wheel a determined amount.
On the other hand, the way I do it is to keep adjusting the box in 1/4 - 1/8 turn increments until it reaches a point that the steering wheel will not readily "unwind" and return to center in a slow turn. I do road tests at about 20MPH to establish this. Then I back it off in small increments until the wheel unwinds freely when turning in each direction. Once that point is found, I then back off the adjustment about 1/8 - 1/6 of a turn and do what Orn said concerning putting it on stands and checking for any binding when steering.
Old Mar 4, 2004 | 08:54 PM
Rackpatrol's Avatar
Rackpatrol
My thanks to Big Orn & CowboyBilly9Mile Ill try that .It happens to be on a 1995 bronco.
