caster correction?
Old Aug 21, 2017 | 10:30 AM
  #106
Shreve T's Avatar
Shreve T
Originally Posted by Hackenbush
I used the moog's in my shop for years and they work perfect, But I used these they were a lot easier.
These sleeves have a fixed positive camber and caster change and are designed specifically to align trucks that have been lifted or to provide more caster. Use a 23268 on the driver's side and a 23269 on the passenger's side.
Speciality Products
Front Adjustment range:
23268 Cam +.50 / Cas +2.3
23269 Cam +.30 / Cas +2.6
The Moog's are fine though.
Thank you, I used the ones that ICON supplied and now developed a right hand pull.. I seen where you posted these the other day..
Old Aug 23, 2017 | 04:38 AM
  #107
BGMSPD's Avatar
BGMSPD
Brackets installed and truck realigned with stock bushings and it drives straight as an arrow and tightened the steering back up. Thrilled with how it drives now. I'm glad I finally found out what was needed to make this truck enjoyable to drive again. I can take my hand off the wheel at any speed and no issues.
Old Aug 23, 2017 | 04:43 AM
  #108
Wirelineman79's Avatar
Wirelineman79
Thank you BGMSPD I'll be ordering some soon. Do you know if wicked customs is the only company that's making these for the 2017?
Old Aug 23, 2017 | 06:41 AM
  #109
BGMSPD's Avatar
BGMSPD
Not sure but they were the only company I found when looking for them. Plus they spent about 20 min on the phone answering all my questions. They also offer coating options if you want the brackets coated and not raw. I had them coated locally.
Old Aug 23, 2017 | 06:45 AM
  #110
kylant's Avatar
kylant
was it aligned to the new 2017 specs? most alignment shops were using the 2016 specs, from which I understand, are much different
Old Aug 23, 2017 | 06:50 AM
  #111
BGMSPD's Avatar
BGMSPD
I mentioned it to the shop and to be honest didn't ask afterwards because it drove perfectly. I forgot to get the printout to see exactly what it was set at because I was thrilled that it drove properly. I'll grab the printout today and see but either way, this is how I expected the truck to drive just wish I tried this fix sooner.
Old Aug 23, 2017 | 07:18 AM
  #112
Wirelineman79
Did you have any bump steer before and if so did the drop bracket help?
Old Aug 23, 2017 | 07:46 AM
  #113
BGMSPD's Avatar
BGMSPD
Yes I did prior to the brackets and it took it almost completely away. I'm going to do a steering stabilizer just to get rid of the last little bit. I have a dual setup from Kelderman I was waiting to install, if need be, after the brackets were in. I'll probably get that put on today and let you know the final outcome as well.
Old Aug 23, 2017 | 07:54 AM
  #114
afacey's Avatar
afacey
They were able to use stock bushings? I thought the brackets only provided 1°. I have almost the exact setup as you.. tires, level, etc.
Old Aug 23, 2017 | 09:37 AM
  #115
user 474747383's Avatar
user 474747383
Curious to see the Alignment print out. Would have been some help if we could see the print out from the previous Alignment also. 1 deg isn't much of a help to the way it was described as handling before. Also make sure they use the 17 software, You can tell if they scan your Vin# then select HD or Standard. Big Difference in HD vs Standard Specs.
Glade to see your heading in the direction you wanted.
Old Aug 23, 2017 | 01:30 PM
  #116
Wirelineman79
Does anyone know if the radius arm drop brackets for the 17's are the same as the previous body style?
Old Aug 23, 2017 | 03:16 PM
  #117
BGMSPD's Avatar
BGMSPD
I don't know for sure but if you call Wicked Customs i'm sure they'll take the time to tell you. And i only say that because i had a good experience on the phone with them. I can't even get someone from BDS to call be back so i gave up on them.
Old Aug 23, 2017 | 03:19 PM
  #118
BGMSPD's Avatar
BGMSPD
They did use the stock bushings, and i'm almost positive that i was told that the brackets give you about 2 degrees with the 2" lift so that's why i could use the stock bushings over. I could be wrong on the degrees but i'm positive on the stock bushings.
Old Aug 23, 2017 | 03:30 PM
  #119
Wirelineman79
So the top photo is from my 17 and the bottom is from an 11 (yes my 17 is dirtier than my 11). I feel like these are pretty close to the same. I didn't crawl under and measure them but from looking I'd say a bracket from 11-16 model should work. They are quite a bit cheaper on eBay I'm just not sure if the designs are as good.
Old Aug 23, 2017 | 03:57 PM
  #120
BGMSPD's Avatar
BGMSPD
Here's a photo installed.
