caster correction?
Old Jan 9, 2017 | 04:20 PM
225nontypical's Avatar
225nontypical
i did not have any problems with my 6" fabtech kit.
Old Jan 17, 2017 | 07:16 PM
Pvincentt's Avatar
Pvincentt
Does anyone know or have the factory caster alignment settings? I found on the carli suspension blog what they found when they put their 2017 on a machine stock (3.2 degree left front, 3.9 degree right front) just wondering if anyone had any official info to compare. Having a thing with my ford dealer who's 18 year alignment guy who did not install my adjustable caster bushings because he said they weren't needed and caster was perfect without them....after the 2.5 inch level kit was installed. He said this in front of the service coordinator and the parts and service director. Reading the alignment report they gave me ...funny everything is on there except the caster reading. Looks like I might have to take it somewhere else to see where its at before discussing it further with said ford dealer.
Old Jan 17, 2017 | 07:51 PM
mjf6175's Avatar
mjf6175
2017 & ford f350 specs alignment specs 3995 f350 ford f150 forum community of ford modified - Foundmycar.net
Old Jan 17, 2017 | 08:03 PM
Pvincentt's Avatar
Pvincentt
Thanks...seems like a pretty wide range. I'm guessing though what carli's f250 was aligned at from the factory is what we should be shooting for...or does it matter?
Old Jan 17, 2017 | 08:31 PM
kylant's Avatar
kylant
Rutcutter said his caster was out of spec after a 2" level.
I would bet shooting for Carli's initial stock specs would be good
Old Jan 17, 2017 | 10:12 PM
Magoo22's Avatar
Magoo22
I'm not sure if the 2017 is different or not but I like 4.5 to 5.0 deg of castor on my truck. I am at 5.0" of lift and run 325/65r18 tires. It is slightly lose with anything less on my unit. Truck tracks and steers like it did from the factory. I will add that I went with OUO radius arms to get that much castor dialled in. My personal opinion is that Castor is your friend...
Old Jan 30, 2017 | 08:09 AM
kylant's Avatar
kylant
i will be installing my level today with the carter correction shims.
can anybody tell me the proper torque for the upper ball joint nut?
I have seen both 69 ft/lbs and 150.
I am pretty sure 150 is for the lower
Old Jan 30, 2017 | 04:25 PM
kylant's Avatar
kylant
tried to install shims, but I could not get the factory shim out.
any suggestions?
Old Jan 30, 2017 | 04:45 PM
user 474747383's Avatar
user 474747383
You have different specs for different Service trucks
These are for (Heavy Duty Suspension, Extra Heavy Duty Camper, Snow Plow Suspension) set up's Via Hunter Alignment Machine..
Caster specs are 1.5 Deg to 4.1 Deg
Camber is -0.6 to 0.9
Tow is -0.08 to 0.18
Old Jan 30, 2017 | 06:50 PM
347Flatty's Avatar
347Flatty
Any other usable part numbers for caster correction cams? The only ones I'm seeing are from eBay and older models. I saw the earlier post but checking what others are using?
Old Jan 30, 2017 | 07:43 PM
user 474747383
Mcbayperformance.com
Old Jan 30, 2017 | 09:24 PM
347Flatty's Avatar
347Flatty
How are cams/bushings placed (directional) and are they adjustable somehow? I've done plenty of suspension work but never with these.
Old Jan 30, 2017 | 09:35 PM
  #28
17PSD's Avatar
17PSD
Originally Posted by kylant
no.
per Radio, end of the month
End of January, or February?
Old Jan 31, 2017 | 08:10 AM
  #29
kylant's Avatar
kylant
i was told january when I called
Old Feb 1, 2017 | 03:50 PM
  #30
347Flatty's Avatar
347Flatty
I spoke with Moog today and they stated part number 80126 is a +/- 2.5 degree and part 80154 is fully adjustable from -2.5 to +2.5 and anywhere in between. So I went with 80154 but haven't received the truck yet.
