Driving lights always on
Old Jan 1, 2017 | 03:54 PM
dieseldrew's Avatar
dieseldrew
Hello brethren truck lovers, I did a basic search and came up empty handed but hoped someone could help or lead me in the right direction.
I have a 2010 F-150 Scab FX4, was trying to locate the correct wire and get it connected to the correct source to keep my driving lights on both low and high beams ? As everyone knows the lights cut out when high beams are used, I want to eliminate this in-activity.
When I'm going back and forth to work here in Deer Country I want to try and light up as much road and shoulder so I can to avoid costly mishaps.
I know what it boils down to is a constant 12v supply being connected to the trigger wire for the relay to turn the lights on.
My issue is it's F-ing Winter here and I'd like to make this as pain-free as possible without having to reserve garage time and try and get this done outside on a decent day in short order.
Thanks for reading, Drew
Old Jan 1, 2017 | 04:52 PM
rjniles's Avatar
rjniles
This is not a wiring change, it is a software change. You need to get your dealer to do this or use FORScan to modify the software.
This feature is nicknamed the "Bambi mode".
Old Jan 1, 2017 | 04:58 PM
dieseldrew's Avatar
dieseldrew
Hmmm
Sorry, I'm not familiar with Forscan. Would that be a dealer scanner ?
Old Jan 1, 2017 | 05:09 PM
rjniles's Avatar
rjniles
FORScan is software you can down load from the net and along with a plugin for your OBD port, modify your truck's as built software. Dealers use a system called IDS.
Search FORScan on the forum.
Old Jan 1, 2017 | 05:17 PM
dieseldrew's Avatar
dieseldrew
Thanks for the info. And to think I thought it was old school like wiring.
Old Jan 2, 2017 | 07:06 PM
fastback89's Avatar
fastback89
Just turned my daytime lights on with Forscan this past weekend.
Old Jan 3, 2017 | 07:15 AM
Olytlr's Avatar
Olytlr
Forscan doesn't play well with '10 and previous years that use a GEM module. I am sure there is a way but not many pre-'11 users out there.
Old Jan 3, 2017 | 11:28 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
So what I did to keep the factory fog lights lit during high beam use, is added a wire coming off my AUX high beam LED lights (they use a relay) and wired it to the positive side of the drivers side fog light. This just back feeds the fog light circuit and keeps both lights on. I have not had any issues with this set-up in over a year of running it and here in Alaska I run my high beams A LOT in the winter months.
Old Jan 5, 2017 | 08:18 AM
rbentnail's Avatar
rbentnail
http://www.ebay.com/itm/FORD-F150-Truck-HIGH-BEAM-FOG-LIGHT-KIT-Turns-Fogs-Back-On-W-High-Beam-Lights-/150552955416?pt=Motors_Car_Truck_Parts_Accessories&hash=item230da7ca18&vxp=mtr&rmvSB=true
wallz
Mar 25, 2014 06:42 AM
otpracer100
Nov 9, 2008 08:37 PM
fordman311
1997 - 2003 F150
Feb 20, 2005 04:47 PM
2K3 Mach
1983 - 2012 Ranger & B-Series
Sep 4, 2003 02:35 PM
