Make Fogs work with park lights
Old Sep 2, 2003 | 08:59 PM
2K3 Mach's Avatar
2K3 Mach
Has anyone made their fog lights work with only the parking lights on a '98 or newer? (Obviously if they don't already...)
What's the best way?
Old Sep 2, 2003 | 09:40 PM
Hank85713's Avatar
Hank85713
If aftermarket wire in thru a relay which uses the power wire to the fog lights as the initiator.
I wired in run lights to be on with low beams this way, put switch in cab to alow to turn on off by completing the ground.
Old Sep 2, 2003 | 11:56 PM
Scooter29's Avatar
Scooter29
I've done that in the past, only to be harassed by the locals about not being able to shut them off independently from the OEM lights. PITA locals! I use switches and relays for everything now. I run the extra wire, just so I can "light em' up " when I go by, just a quick blip! But hey, this is NY!
Talk with you guys later....
Old Sep 3, 2003 | 10:02 AM
WXboy's Avatar
WXboy
Both my '99 and my new '03 came from the factory wired that way. What's up with these Rangers that aren't? Different laws in different states or something?
Old Sep 3, 2003 | 10:27 AM
PSKSAM2's Avatar
PSKSAM2
When I put them in on my '98 with the "stock" kit, I was suprised that they didn't come on with the parking lights too. I expected it to be like my Mustang where they come on with the parking lamps if the switch is on and only go off with the highbeams.
-Jim
Old Sep 3, 2003 | 04:48 PM
neodragon's Avatar
neodragon
What I did was, pulled the headlights switch out, then took the hot wire from the foglights and spliced it into the wire that goes to the parking lights. best way to figured out which wire to splice into, is to take a needle and wrap the foglights wire around it then stick it through each wire till the fogs come on. good luck
Old Sep 3, 2003 | 07:06 PM
Rockledge's Avatar
Rockledge
A few months back I thought about doing this mod as well, and Bob Ayers was nice enough to give me a hand figuring out how to go about it. I sent him some schematics and he sent them back to me with some comments and tips (thanks Bob!) The image below represents the plan we came up with.
(NOTE: I also thought about wiring the fog lights directly to the parking lights, but was advised by Bob that the fog lights pull a significant larger current than the parking lights do, and that could possibly lead to problems down the road)
Old Sep 3, 2003 | 08:20 PM
Ken00's Avatar
Ken00
My 2000 has an extra relay thats not shown in the above diagram. I'll have to get the diagram another time, don't have my disk with me.
Old Sep 4, 2003 | 11:57 AM
Ken00's Avatar
Ken00
Here's the diagram of how my fogs are wired.
Old Sep 4, 2003 | 01:38 PM
WXboy's Avatar
WXboy
I'm curious now...how come Ford wires some trucks up like this from the factory, and others they don't...even though all the trucks in question are sold in the U.S. (and therefore have to meet the same DOT rules)?
Old Sep 4, 2003 | 02:35 PM
Ken00's Avatar
Ken00
It must have been something to do with the laws, the added relay cuts the fogs off when the heads light are on high or flash to pass.
