Do motor mounts deteriorate?
Old Dec 24, 2016 | 07:15 PM
IHbase's Avatar
IHbase
When under heavy load and high RPM, the drivetrain vibration feels more severe than I think it should. Sounds as though the engine wants to come though the firewall when wide-open and loaded down.
Do the factory motor mounts absorb any vibration or are they solid? If they absorb vibration, do they wear out?
Thanks,
-Mike
Old Dec 24, 2016 | 07:53 PM
tfunk88's Avatar
tfunk88
Yep, the rubber can break down. Bad motor mounts are pretty damn noisy and "vibrate-y"
Old Dec 24, 2016 | 10:46 PM
Yahiko's Avatar
Yahiko
If you have access to someone that has a VCM2 I would also run a contribution test.
An injector acting up will shape things fairly good too.
But yes the mounts do have a rubber portion and if exposed to some chemicals
they can break down over time. Should not be too hard to swap in some new
rubbers if you have a cherry picker type hoist.
Take a look at them and see how the rubber looks and feels.
Old Dec 25, 2016 | 09:23 AM
69cj's Avatar
69cj
U joints or drive shaft carrier bearing could also be going south and showing up at higher rpm's and torque. Put the truck in drive and do a power brake. Does the engine appear to torque up more than normal?
Old Dec 25, 2016 | 09:36 AM
KDAVID1's Avatar
KDAVID1
Look real good for a missing piece in the ujoint..........
Old Dec 25, 2016 | 06:33 PM
Yahiko's Avatar
Yahiko
Mike is right and I had a carrier bearing go on me. It was almost
like running over a rumble strip that went on forever as long as
you were on the throttle. Take you foot off and coast and it settled down.
Merry Christmas
Old Dec 29, 2016 | 08:01 PM
IHbase's Avatar
IHbase
Thanks for the replies. I've inspect U-joints closely and I can not see anything or detect any driveline slop.
I'll inspect the motor mounts and see what it would take to get a VCM2 test performed.
Thank you for your assistance.
-Mike
Ranger92
General Automotive Discussion
Nov 22, 2008 02:24 AM
4x41977
Engine Swaps
Dec 11, 2007 07:46 PM
wvmudder
Engine Swaps
Oct 19, 2006 10:26 AM
78 Ranger
Feb 26, 2006 11:10 PM
nzabka
Jul 24, 2003 03:44 PM
