Sponsored by: Real Truck
Engine block heater question
Old Dec 12, 2016 | 11:37 AM
CincyPSD's Avatar
CincyPSD
It got down to the low teens the other day and I thought I would use my engine block heater to see how well it works. But when I got in the oil temp was basically the same as the air temp (it may have been 5-10 degrees warmer but still not above 20*F) after being plugged in for 2-3 hours. Is something wrong here? I would have thought it would have warmed it up or does it not affect the oil temp? If not, what does it warm up?
Old Dec 12, 2016 | 01:22 PM
Just Strokin's Avatar
Just Strokin
How about some specifics about your truck, yr, engine. Also what size extension cord where you using?
Old Dec 12, 2016 | 02:18 PM
CincyPSD's Avatar
CincyPSD
Sorry. Thought all that was in my sig but see it's not. 2016 6.7. I was using a regular outdoor 100 foot cord because that's all I had.
Old Dec 12, 2016 | 02:26 PM
Tim C's Avatar
Tim C
It heats the coolant, not the oil. There may be minimal oil heating just in the oil cooler, but that's less than a quart or so, most of the oil will be in the pan or filter, it will stay cool because the air circulating around under the truck when the wind blows.
Block heater will raise the coolant temp a good bit but it's still usually less than 100*f, it will warm the block and heads for easier starting though. Plus the heat usually gets warm faster.
Old Dec 12, 2016 | 03:14 PM
thomabb's Avatar
thomabb
Use the shortest extension cord you can, and use a hefty gauge. You will lose some heat in the cord, but the shorter and fatter you go the more efficient it will be.
Old Dec 13, 2016 | 10:17 AM
ligito's Avatar
ligito
Use a 12 gauge short cord.
Heavy duty insulation does not equal heavy duty wire size.
Old Dec 14, 2016 | 06:08 AM
bobv60's Avatar
bobv60
This question was just addressed over on the 6.7 Diesel section of this forum. The block heater is a cold starting aid, not ment to have a warm trick when you get in.
3 hours in cold temps might not be long enough . One recommendation was at least 5 hours.
if you head over to the 6.7 section you should find the post. You will also find you will get quicker and more reliable results there when asking 6.7 Diesel engine related questions
Old Dec 14, 2016 | 08:15 AM
MadWolf's Avatar
MadWolf
I have a 6.2, but I tried mine a few times, when the temp was in single digits, just to be nice to my truck. However, Even at 0 F, it would still start without the heater, no problem. When I did plug the heater in for 2 hours, the engine turned over a little faster/easier, like it would if it was slightly warmer out. That's the only noticeable difference I could tell.
Dmaddox
Jan 20, 2018 10:55 AM
kfederig
Dec 30, 2017 06:36 PM
JB17
Dec 24, 2013 01:53 PM
lexustbs
6.7L Power Stroke Diesel
28
Apr 7, 2011 10:18 AM
Speedjester
Jan 3, 2011 07:49 PM
