What Temps. are you seeing with block heater
Imagine that you had a 900 watt kettle(most draw about 1500) and that the kettle was about 750 lbs of compacted graphite iron filled with 28 quarts of liquid, exposed to a temperature of 21 degrees and a possible wind chill. I do not think you should expect much more of your block heater.
Our temp last night was 11 degrees. Truck plugged in oil temp at start up was 48 degrees. Truck sat outside at work today for 10 hrs not plugged in,temps were 19 degrees, on start up oil temp was 27...interesting thing is my tran temps seem to stay very close to oil temps.....so far anyway....only has 350 miles...we'll see.
I understand that the heater is not going to keep the engine hot, but I was expecting something more than that. Only a 10 degree swing between ambient temp, and oil temp? My tranny temp was only 1 degree off of the oil. If the heater is working then shouldent the oil in the motor be warmer than in the transmission? Or does it warm the trans too?
But as far as engine temperature, believe me the engine is getting warm. I can track coolant temperatures with my ScanGauge. From this I can tell you that three hours on the block heater at 0 degrees F will yield an engine(coolant) temperature of over 60 degrees.
And with the coolant at 60 I may see an oil temperature of 15-20 degrees. This is normal.
The block heater is heating your engine, you're simply looking at the wrong gauge.
I believe the primary purpose of a block heater is to keep the combustion chambers from getting so cold that the fuel doesn't want to ignite.
I've started mine at -10 with and without the block heater, and there is a noticeable difference. For me the block heater is simply a tool to get better fuel economy, as this engine really doesn't need it for the vast majority of the temperatures we see up here in the winter time.
I was curious what my block heater would do during our cold snap here in Houston. I plugged in the block heater a few hours ago just to see what, if any, temperature differential there might be. I read this thread and went out to the truck to see if there was any effect to be detected by using the block heater.
Right now ambient temperature is 31F with a stiff North wind. My transmission temperature is 19F and my oil temperature is 51F per my Information Screen. I did not start the truck. Hopefully this information does not cloud the issue.
I was thinking about this a bit last night as I was standing in a 40 mph, 15 degree wind. It is interesting that they decided to heat the water jacket. By design it draws heat away from the engine. I am willing to bet that things like orientation to the prevailing wind has a big impact on the temperature delta you can expect to see over ambient.
Think about that big radiator facing into the wind, cooling down all that heat a 900 watt heater can produce. If the "block" heater is only heating the water, I wonder what impact the near frozen oil has on providing sufficient lubrication during that critical start-up period.
From my experience flying small airplanes, the goal was to get that oil warm enough to insure that during the first couple of minutes of operation we could get pressure and flow to the critical elements. Wonder what is different on a truck engine?
Remember that the thermostats are traditionally connected to the upper radiator hose, which comes into the water pump from the top side. Convection is going to push the hot water to the upper areas of the engine where it will be blocked by two closed thermostats. The only way warm coolant could get to the radiator is if there was heating action near the bottom of the block so that warm water could work it's way down the lower radiator hose.
But the block heater isn't at the base of the engine, it's in the passenger side cylinder bank. Presumably for this exact reason.
Block heaters always heat the cooling sytem and are VERY common on diesel engines of all shapes and varieties. Oil pan heaters are also common, but much less so than block heaters.
