Plugged In All Night
Old Jan 20, 2018 | 08:31 AM
Dmaddox's Avatar
Dmaddox
I have a 17 F250 XLT CCSW Power Stroke of course. I have been plugging it in at night temps around 0 deg. When I get in to start it up in the morning my oil temperature is only around 30 deg. Is this normal?
Old Jan 20, 2018 | 10:31 AM
Mike189677's Avatar
Mike189677
The block heater heats the coolant that is in the engine block not the oil so the oil isn’t reviving any direct heat.
Old Jan 20, 2018 | 10:51 AM
CBEllis's Avatar
CBEllis
Yep, check the temp of your engine coolant and see if the heater’s functioning properly. Really, anything past 3.5-4 hours is a waste of electricity. It’s reaches temp in that time and doesn’t go any higher so, a timer on the outlet may save you some cash. It draws about as much power as a blow dryer so, an all-nighter will draw quite a bit.
Old Jan 20, 2018 | 10:55 AM
Dmaddox's Avatar
Dmaddox
Thank you I will try it now and report back in a few hours. I was miss lead thinking it was and internal oil pan heater.
kfederig
Dec 30, 2017 06:36 PM
CincyPSD
Dec 14, 2016 08:15 AM
JB17
Dec 24, 2013 01:53 PM
Jumbo131
6.7L Power Stroke Diesel
Dec 11, 2012 09:59 PM
Speedjester
Jan 3, 2011 07:49 PM
