Replacing the EBP sensor?????
Old Jan 15, 2010 | 05:11 PM
natew's Avatar
natew
My Exc. has lost power and mpg. After reading many posts, I have just ordered a new EBP sensor hoping to cure the problem. Today I disconnected the sensor and drove around. No difference except that the service engine light came on. I connected the sensor and shortly after driving the light went off. Does this mean that the sensor is not the problem and that the sensor is working???? Thanks
Old Jan 15, 2010 | 08:05 PM
F350-6's Avatar
F350-6
That's very possible. Have you tried cleaning the tube? Remember to clean out the fitting on the manifold?
Old Jan 15, 2010 | 08:35 PM
jasonch's Avatar
jasonch
i changed mine back in november, i changed the tube(it was in 2 pieces) and the sensor. i also cleaned as mentioned above the holes on the bracket for the sensor and the exhaust. i could not tell a difference in the way that it drives, and not really in my mpgs, but the wastegate is working for sure now as to before it was not. hope this helps you.
Old Jan 16, 2010 | 09:34 AM
boertje's Avatar
boertje
Just took mine apart too. The tube was pretty gummed up but not completely plugged so I cleaned it as per the "guzzle" method with weed eater cord and brake cleaner and got it squeaky clean and open. The sensor was OK...no gunk. Now waiting for my dieselsite boots to replace my oily stock ford intake boots.
Old Jan 16, 2010 | 09:38 AM
Izzy351's Avatar
Izzy351
If you have a way to monitor your engine, you can see if the EBPS is working or not. I watch my back pressure with my ScanGauge. At idle, it sits around 14-15psi, and at WOT, it gets up in the 40-50psi range.
Old Jan 16, 2010 | 09:47 AM
robs01f250's Avatar
robs01f250
Hook it up to a scanner and that will tell you for sure what the problem is
Cell's
Apr 3, 2022 10:56 PM
Turfzilla
Nov 28, 2012 12:49 PM
Rusty Axlerod
Nov 2, 2011 04:39 AM
ehgeeray
Mar 26, 2010 09:12 PM
eric777
Aug 11, 2006 01:01 PM
