windshield frame rot?
Old Dec 11, 2016 | 08:28 AM
tjc transport's Avatar
tjc transport
i ain't rite
does anyone know where the windshields leak/rot out on these trucks?
i have started to notice a wet carpet under the park brake pedal on my 02 the past few weeks when it rains and want to correct the issue before it turns into a big problem.
Old Dec 11, 2016 | 08:42 AM
jetdoc's Avatar
jetdoc
Happened to mine. Top passenger side rotted through. Was cheaper to swap the cab than to replace the roof skin.
Old Dec 11, 2016 | 08:53 AM
tjc transport
i ain't rite
ok .mine is on the driver side i think because that is the only place that is wet. and there is no noticeable issues when the gasket is peeled back.
Old Dec 11, 2016 | 09:00 AM
jetdoc's Avatar
jetdoc
I could see the flashlight through mine. The salt they use on the roads kills these trucks. Gently press on the inside of your windscreen, if the sealant is compromised there will be movement.
Old Dec 11, 2016 | 07:19 PM
F350-6's Avatar
F350-6
Get a water hose out. Start at the bottom corner of the windshield and spray with low pressure water while having someone watch for leaks inside. Or do it yourself and run back and forth.
If the corner doesn't leak, move to the left toward the center of the cab along the bottom of the window. After that, start working your way up along the A pillar.
You can probably move about 12" at a time and leave it in that spot for 15 - 25 minutes. Remember water runs downhill so it's important to start low and work high while diagnosing.
If it's too cold to water test, I guess you could spray the windshield with soapy water and try to pressurize the cab.
Old Dec 12, 2016 | 12:35 PM
tjc transport
i ain't rite
tried that already Chris, and did not get anything that i can see.
it is definitely coming in, i just can't find from where.
Old Dec 12, 2016 | 06:15 PM
F350-6's Avatar
F350-6
You sure it's coming down and not up then? You're talking in the general area of wheel spray.
Old Dec 13, 2016 | 07:38 AM
jetdoc's Avatar
jetdoc
We have a light duty F250 at work that the windshield is loose. You can press outward on the upper left hand corner and it moves ever so slightly. It leaks upon the fuse box and drains the battery.
Old Dec 13, 2016 | 09:14 AM
ZachinCO's Avatar
ZachinCO
Mine had a smaller rust spot from where the windshield had cracked and run to the edge. It happened to be upper PS. When I get a new windshield every other year I have it inspected.
ingo
WTB - Parts & other
Apr 19, 2017 06:56 AM
Kladd1987
Nov 22, 2013 11:49 AM
jhrobert
Mar 18, 2008 01:35 PM
McLeod
1966 - 1977 Early Broncos
Nov 29, 2006 04:29 PM
retro build
1947 and Older Ford Trucks
Jul 4, 2003 09:07 PM
