Winter 2016/2017 General BS Thread
I hope y'all are safe and warm...
Then the upstairs area in the kitchen is 180 sq feet. This doesn't get moisture barrier as that's under the house. Think I've found this.
The laminate I've found is around 90c sq ft, but doesn't have an attached pad. So need to add foam. That would be for all areas right? This is where I'm a little fuzzy right now. Trying to figure out which pad to go with, that doesn't cost nearly as much as the flooring! Any ideas or suggestions?
this was what we used when we did the floor in my room.. the laminate we got for my room already had it on there but we did a 2nd layer because dad didnt want to hear me stomping around in my room lol.. but when we did the dining room downstairs we used the same stuff. i dont know if it did anything for sound.
I put down laminate flooring in three rooms in the first house we bought. I put down the thin foam under all of the new flooring. But I'm thinking it was with that moisture barrier, just a thin plastic film along with the foam. Hey that wasn't too bad.
Yes, I will have another toddy!
So that stuff you linked Shawn, it's about 75 cents a sq ft! That's kind of higher than I was thinking.
I found this stuff: https://www.lowes.com/pd/FloorComfor...yment/50402206 and I'm wondering if that will do the job. It comes in at 40 cents a square foot.
Oh and is this the right stuff for the concrete basement to go down first? https://www.lowes.com/pd/Blue-Hawk-1...yment/50149788
Also, ya'll think 20 cases of flooring will fit in a 5.5 ft F150 bed? or should I plan on taking one of the trailers with me as well?
on the price keep in mind josh the one your wanting to use is way thinner than what we used under mine.. which is why for the difference in price... the one in your link is only 2mm thick... where the one i linked to was 15.875mm thick.. both will be just as easy to lay under the flooring... if you have alot of noise from like the furnace equipment in the basement or wanting to limit the amount of sound between the floors the thicker barrier would be better for that... the nice thing with the roll was i could go from wall to wall before cutting it... both will probably lay just as easy as each other...
for the concrete floor barrier i cant say.. we just used the same stuff upstairs as we did downstairs...
Thanks for the well wishes on the dog.
A little drugs and cleaning of the wound and Keeper is back to his old self.
Lucy & Keeper chase each other all over the yard so we don't have to chase them! This way when inside they are pretty mellow from all the running around.
I hope with this weather my water don't quit then I am on county water and no trees any were near the line.
I do have a well for outside watering, don't k ow if I would trust to drink it but has not hurt the dog!
Keep warm everyone
Dave - - - -
Keep warm everyone
Dave - - - -
On the county/well water debate.... I'd take well water over County water every single day. I love my well water.
