Need help on suspension
Old Nov 29, 2016 | 09:51 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
I use Jack stands right past the spring hangers front and back. I don't recommend raising your trailer with only Jack stands behind the rear springs hooked to the truck because it adds excess weight and stress on the pin area.
Denny
Old Nov 29, 2016 | 11:09 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Denny
After lifting the trailer near the front and rear spring hangers, do you support the front in anyway like with the landing gear with large blocks under them?
Old Nov 29, 2016 | 11:24 AM
rvpuller's Avatar
rvpuller
Yes I will lower the front jacks so they are down hard but not enough to transfer weight to the back jack stands, I also have Power Twin II rear stabilizer that I lower just in case but raise them back up before removing the jack stands. I use a friend's heavy duty Kansas Jack stands but I'm still very careful when its off the suspension. I will even place my lighter jack stands under the axles when the tires are off.
Denny
Old Nov 30, 2016 | 09:58 AM
WE3ZS's Avatar
WE3ZS
Originally Posted by '65Ford
I didn't see it mentioned but might want to replace any nuts and bolts that you take out. My camper shackles have stover nuts which are usually one time use.
Might consider switching to greasable bolts and brass bushings while you're at it.
Originally Posted by 69cj
While at it, I'd replace all the shackles and pins to lubeable pins with bronze bushings. Did that on mine for app. 100 bucks. Old pins had plastic bushings that were about 1/2 gone.
I just ordered this set of heavy duty shackles and wet bolts with bronze bushing on Friday, they were delivered yesterday.
https://www.amazon.com/gp/product/B0...=AHSEAWK2CKAVE
Old Nov 30, 2016 | 02:38 PM
scraprat's Avatar
scraprat
Top Answer: 5
You can't go wrong with a set of shackles that can be greased as long as you keep greasing them.
That's on my to do list to replace as soon as I get to a winter spot to sit and get some mail/ packages sent towards.
Old Nov 30, 2016 | 03:45 PM
69cj's Avatar
69cj
That's them. I grease them whenever I'm doing any other service on the trailer or before any long trip. Takes maybe 5 minutes. I just get on a creeper and go one end to the other and wipe off any excess with a rag. Really quieted down the moans and groans when parking her.
Old Nov 30, 2016 | 03:48 PM
senix's Avatar
senix
Very nice upgrade there. I will probably need to do this by the end of next summer. Rig will have enough miles on it for a wheel bearing and seal service and that would be a good time for this as well.
Old Nov 30, 2016 | 04:13 PM
17 Oaks's Avatar
17 Oaks
GREAT TIPS, thanks to all
Old Dec 13, 2016 | 08:28 PM
jsm180's Avatar
jsm180
Originally Posted by senix
Welcome to FTE. This thread has to do with trailer suspensions.
Spammer, look at the link.
Old Jun 20, 2017 | 02:52 PM
Dakar Dad's Avatar
Dakar Dad
Has anyone found the ultimate grease for trailer suspension?
I have the wet bolts and bushings and use Stay-lube Moly-Graph grease. I use this grease for everything else but it doesn't seem to last very long on the trailer suspension.
I grease it every other time we take it out, but say by the end of 500 miles it is creaking again while I am backing it up into the driveway.
Old Jun 20, 2017 | 05:43 PM
17 Oaks's Avatar
17 Oaks
Green Grease | The Best Grease Money Can Buy!
I use this on my offroad Jeeps and trailers, that see a LOT of water and extreme use...NOTHING better!
Old Jun 21, 2017 | 10:20 AM
Dakar Dad's Avatar
Dakar Dad
Alright, I like the reviews, thanks.
timmygyu
1978 - 1996 Big Bronco
Jun 24, 2012 07:33 PM
riverrat41
Mar 17, 2011 06:20 PM
99FORD EXPY.
Jun 29, 2009 07:51 PM
Adam0331
Oct 25, 2008 09:46 AM
ejpreston
All Things Towing
Jan 9, 2005 11:14 PM
