Steering is sketchy as hell
Old Nov 17, 2016 | 11:13 PM
Dude-Ford's Avatar
Dude-Ford
I can't figure out if it's the power steering pump or the steering box or something else?? I've tried the adjustment thing on the box and it didn't help worth a damn. Long story short I swapped trucks with my brother and thought I was going to die on the freeway today. If you turn the wheel left it's stays left and if you turn it right it stays right. Coming out of a turn, it still wants to turn. It was windy as crap today here in OKC and I couldn't keep the damn thing straight to save my life.
Old Nov 18, 2016 | 01:22 AM
Rikster-7700's Avatar
Rikster-7700
Has it had the ball joints replaced lately? They can cause it to bind that way if not installed properly, also the adjustment on the steering box you did may be too tight? Have you tried backing it off some?
These are the only things I can think of right now, it's late..... I am sure someone else will chime in too with other thoughts.....
Old Nov 18, 2016 | 08:27 AM
BillyBob69's Avatar
BillyBob69
What Rikster said ^^^^^
Back off the adjustment 1/4 turn and see how it does. Then check the ball joints.
Old Nov 18, 2016 | 11:45 AM
Dude-Ford's Avatar
Dude-Ford
The ball joints are brand new haha
Old Nov 18, 2016 | 12:50 PM
knottyrope's Avatar
knottyrope
steering box too tight or the steering ujoints are binding
best to remove link from pinion arm and see if the steering still binds
Old Nov 18, 2016 | 06:38 PM
Rikster-7700
Did this problem appear soon after they were installed? If so it was probably an incorrect installation as I mentioned above........
Old Nov 18, 2016 | 06:53 PM
Dude-Ford's Avatar
Dude-Ford
They were replaced before truck was purchased. Is there a way to tell if were are improperly installed .
Old Nov 18, 2016 | 08:48 PM
z31freakify's Avatar
z31freakify
New steering box may be your solution. On my wife's X I adjusted the steering box to tight and even after loosening back up it stayed the same, new steering box and all was well. I bought a reman from Autozoo.
Old Nov 19, 2016 | 12:22 AM
retiredsparky's Avatar
retiredsparky
If even one ball joint is damaged during installation by pressing in at an angle, that additional friction can mess up steering. But, most likely this problem will be fixed by spending $$. I am thinking steering box.
Old Nov 19, 2016 | 04:56 AM
Tugly's Avatar
Tugly
I'm thinking steering box. The most common problem there is one person or shop will tighten it up in an attempt to improve steering, then another shop or person will try the same thing because they didn't know it had been tried before. The next thing you know... 3 or more people try to tighten it up, then the binding starts.
Worn box:
Same day - after Redhead install:
Old Nov 19, 2016 | 07:56 AM
MoBill122's Avatar
MoBill122
Papa Smurf
Have had play in steering issue for some time. A while back, had the spouse turn steering as I laid under truck to watch... I was shocked. My driver side spring ubolts were loose... the axle moved back and forth. Tightened up bolts and most of steering play is gone now. Have no idea why bolts were loose... have never touched them before.
regret
36
Jan 13, 2017 06:59 PM
davidwags3
Mar 19, 2014 11:35 AM
Capt.Schenk
Jan 24, 2012 03:41 PM
Mitch1407
Jul 30, 2011 11:47 AM
MVARGAS
1978 - 1996 Big Bronco
Jun 5, 2003 05:41 PM
