PCM problem
Old Nov 15, 2016 | 08:51 PM
Montanafisher's Avatar
Montanafisher
PCM problem
I acquired a high dollar diagnostics computer. PF diagnostics I believe is the name. Anyway i tried.hooking up to 02 7.3 and it won't connect. Connects and communicates fine with a number of other vehicles. Including same year 7.3 my fuses and cigarette lighter are all good. Truck starts and runs but cruise control doesn't work. So my question can a pcm be bad to not establish communication but still start and run truck.
Old Nov 15, 2016 | 11:28 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
If the truck runs the PCM is good. At least good enough. I'd lean more toward the OBDII port being bad, even if the fuse is good.
Got any details on this PF diagnostic thingy?
For the cruise maybe the brake switch is disconnected. There was a recall for faulty switches that caused fires and perhaps the PO disconnected it and never got the recall. Plop your VIN in at the link below to see if the recall was done on your truck.
Ford Field Service Actions
Old Nov 15, 2016 | 11:45 PM
Montanafisher
PF stands for pocket fleet. More on the program and software can be seen at diesel laptops.
As for troubleshooting the obd2 connection is there a process of what to test and proper values to see.
I will check brake switch, but if I can get computer and pcm to communicate I can watch all the switches and sensors on there I believe
Old Nov 16, 2016 | 10:43 AM
pirschwagon's Avatar
pirschwagon
Yes.
Check Pin#16 on the OBD Connector for power. This should have power all the time key in / or out. There are only eight pins used of the 16.
And, Just because the Power Port works does not eliminate a wire issue at the port.
PWM PCM OBD-II Connection on Diesels (7.3L) uses only 8 of the OBD-II Pin Points
Pin# 4 is Chassis Ground. You should have no resistance between Pin#4 and the Chassis Ground.
Pin#5 is Sensor Ground - You should have no resistance between Pin#5 and any Sensor.
Pin#16 (Top Row, First pin OR Bottom Row Last Pin (Narrow End)) is 12vdc and should be active (Hot) with KOEO.
** You should see 12vdc KOEO between Pin#16 and Pin#4. **
Old Nov 16, 2016 | 03:28 PM
garydmundy's Avatar
garydmundy
For cruse control, check and see if your 3rd brake light works (the one on top behind the cab). If it is out, the cruse control won't work. I know, it sounds strange but it's wired that way.
Old Nov 25, 2016 | 06:10 PM
MoBill122's Avatar
MoBill122
Papa Smurf
Agree with others, check the Deactivation Cruise Switch on the brake Master Cylinder. There was a recall on this switch and its blamed on numerous vehicle fires.
Old Dec 30, 2016 | 10:41 PM
ford4ever4wheeler's Avatar
ford4ever4wheeler
Were you able to Get your scanner to connect? Im having the same issue on my 94, snap on modis won't connect to obd1 or 2
Old Feb 17, 2017 | 08:49 PM
Montanafisher
A little delayed but to answer your question no I didn't. Turned out the program needed an extra cable to communicate with early fords. Ended up purchasing AE about a month ago instead
andy's2000
26
Nov 6, 2016 08:42 PM
finallyo3gt
17
Nov 14, 2015 10:43 PM
Lerch7.3
Jun 24, 2015 07:53 AM
OldWoodsDiesel
Oct 2, 2013 06:37 AM
gramicko
Apr 24, 2010 12:27 PM
