No communication with PCM
Old Nov 8, 2015 | 07:09 PM
finallyo3gt's Avatar
finallyo3gt
First, I tried the search tool, I really did...haha.
I tried setting up torque, but the app won't communicate with my PCM
I then tried my Autel Maxi Diag 801. It showed MIL Status: ON with 127 codes. I do not have a check engine light on. I have seen this before with a fan relay setting a code on the body control module rather than the PCM, on a Jeep Liberty. So I found this on a forum:
Straight out of the 97 EVTM for C227, Data Link Connector:
Pin 2: Circuit 914 (T/O), Data (+) from PCM pin 16, through C202 (firewall feedthrough connector)
Pin 4: Circuit 57 (BK), Ground
Pin 5: Circuit 570 (BK/W), Ground through C202
Pin 10: Circuit 915 (PK/LB), Data (-) from PCM pin 15, through C202
Pin 13: Circuit 107 (P), PCM Input from PCM pin 13, through C202
Pin 16: Circuit 40 (LB/W), Hot at All Times from Underdash fuse 16 (15A)
All other pins are NOT USED
Broke out the meter and everything seems to check out EXCEPT, no voltage from pin 2 to pin 4, 5 or ground. Maybe I'm nuts, but that looks like it would explain a lack of PCM communication.
So is there a common place to start, or is it just wire chasing?
Which firewall bulkhead is C202. I see three on the drivers side.
Old Nov 9, 2015 | 12:17 PM
cowmilker08's Avatar
cowmilker08
You're beyond my knowledge of the subject, but here's a bump.
Old Nov 9, 2015 | 01:26 PM
farmert's Avatar
farmert
Have you checked the in cab fuses? I seem to recall the diagnostic port being on the same fuse as the extra power point in the cab. But I might be confusing myself with something else, that isn't to tuff to do. LOL
Edit: The cigar lighter and data point are on the same fuse, #16, 15 amp in cab.
Old Nov 9, 2015 | 02:56 PM
finallyo3gt
Thanks Cowmilker.
Farmer T: I think fuse #16 is the power to the OBD and maybe the power port/cig lighter. That fuse is good, and I do have power at the cig, the power port and the OBD pin 16. I do not have power on pin 2 (data +). Not sure what that voltage should be, but pin 10 (data -) has 5 V KOEO. Pin 13 (Circuit 107 P PCM input) has 0.5 V KOEO. Both are zero with Key off. Just an educated guess, I'm betting pin 2 (data +) should have 5 v also.
Old Nov 9, 2015 | 03:05 PM
Hussler's Avatar
Hussler
Pin 2 is the AUX POWER TRAIN controller which I'm guessing you don't have.
Old Nov 9, 2015 | 03:14 PM
finallyo3gt
Good to know, I was about to start chasing wires.
Based on this: i have the following with KOEO each pin to chassis
Pin 2: Circuit 914 (T/O), Data (+) from PCM pin 16, through C202 (firewall feedthrough connector) : .05 V (basically 0, but enough trace to make me curious?)
Pin 4: Circuit 57 (BK), Ground : O V (expected)
Pin 5: Circuit 570 (BK/W), Ground through C202 : O V (expected)
Pin 10: Circuit 915 (PK/LB), Data (-) from PCM pin 15, through C202 :5 V
Pin 13: Circuit 107 (P), PCM Input from PCM pin 13, through C202 : 0.45 V
Pin 16: Circuit 40 (LB/W), Hot at All Times from Underdash fuse 16 (15A)12V
So if pin 2 should be 0, why can I not communicate with the PCM? What's next?
Old Nov 9, 2015 | 03:22 PM
Hussler's Avatar
Hussler
Don't know anything about the torque App so no help there. Here is a recent thread with some good information on setup that might help ...
https://www.ford-trucks.com/forums/1...umb-olman.html
Old Nov 9, 2015 | 04:15 PM
finallyo3gt
QUOTE=Hussler;15778150]Don't know anything about the torque App so no help there. Here is a recent thread with some good information on setup that might help ...
https://www.ford-trucks.com/forums/1...umb-olman.html[/QUOTE]
thanks for the help. I'll read it again, but as I remember most of his issue was getting that ELM327 connected to His ipad. I also cannot get communication with my scan tool. That makes two devices that both seem to connect to the truck but will not connect to the PCM
Old Nov 9, 2015 | 04:34 PM
Hussler's Avatar
Hussler
Don't know if the Autel Maxi Diag 801 is compatible with the truck, most scanners aren't. OBS uses non-standard OBDII protocol. What year is your truck? 94.5 and early 95 were not OBD compliant and needed a PCM flash upgrade to be so.
Old Nov 9, 2015 | 04:43 PM
finallyo3gt
mine is a 96. The scanner read that it had codes just would not tell me what the codes aresaid communication with PCM could not be established. the torque app connected with the elm327 just would not communicate with PCM
Old Nov 10, 2015 | 06:44 PM
IceboxFX's Avatar
IceboxFX
Well this sure helped me, I couldn't connect to the port on my new truck and after reading this, I checked the fuse. Low and behold:
field expedient repair attempt (not by me)
Old Nov 11, 2015 | 06:34 AM
finallyo3gt
Icebox,
What fuse was that? Is that a jumper on a good fuse. It doesn't appear to be blown.
Old Nov 11, 2015 | 09:28 AM
madpogue's Avatar
madpogue
You can just see the break in the fuse, just off the left leg. But "appear" is the key word. Very small breaks like that can be hard to see, esp. in the lighting in the cab. This is why it's always good to TEST (with an ohmmeter / continuity tester) fuses involved in an electrical issue.
Old Nov 11, 2015 | 09:55 AM
finallyo3gt
agreed. What fuse is that? I have power on the number 16 Fuse to the power port on the OBD and my truck power port, and my cigarette lighter
Old Nov 11, 2015 | 11:23 AM
IceboxFX's Avatar
IceboxFX
Yup that was the #16 fuse for the OBD port and the cig lighter. There was a dime sitting in the bottom of the lighter which must have popped the fuse. Then PO decided to jump with that thin copper wire. It looks burned too on the wire so it must have melted and did not connect good. cig lighter was unplugged when I went to disconnect it so i can put a new fuse without blowing to hook up to the OBD. Connected with the torque app and it seemed to read fine, no codes.
