Transmission problem
Old Nov 13, 2016 | 07:21 PM
fgadsden75's Avatar
fgadsden75
I have a 81 ford f100 with a 302 and aod tranny, I just recently got it back together.
Noticed when I checked my tranny fluid it was a milky strawberry color so I drain the fluid and changed the filter and bought a tranny cooler.
I've flushed it 4 times and the tranny fluid looked a little better, so I took it for a test drive after I set my tranny pressure and 1st and 2nd gear was good got to 3rd and the truck started shaking.
Do I need to flush it again or replace the tranny.
Old Nov 14, 2016 | 09:06 AM
Braggs's Avatar
Braggs
Milky color in the transmission fluid means friction material. Friction material is essential for the correct operation of the transmission. You need to rebuild the transmission, not replace it. Continually flushing the fluid isn't going to replace friction material.
I won't lie. It's a tough job. Lots of hours of manual labor to remove and install the transmission. You can expect to spend a few hundred dollars in parts too.
Old Nov 14, 2016 | 03:00 PM
Franklin2's Avatar
Franklin2
I thought milky fluid means there is water in it possibly? Is your radiator cooler leaking into the trans cooler?
Old Nov 14, 2016 | 03:31 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Milky color means water or engine coolant in the fluid, not friction material. Is there ATF in the engine coolant? If so, the trans cooler in the radiator has failed.
It still means a rebuild. Water in the ATF will quickly destroy the friction material.
Old Nov 14, 2016 | 04:27 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
Reads like there's a breach between the trans cooler and the radiator. ATF will present in the coolant as milky pinkish white if that is the case. Mine has a separate trans fluid cooler which You may want to consider.
Old Nov 14, 2016 | 05:29 PM
maytag906's Avatar
maytag906
^^what they said, probably a leak in the trans cooler.
Old Nov 15, 2016 | 08:42 AM
Braggs's Avatar
Braggs
Ok, but when I took off my transmission pan last year, I too saw lots of white/silvery color in my transmission fluid too. Some spots were dark. It stuck to my hands and wouldn't come off without gasoline. Definitely not water. I've seen the same thing too when taking off an oil pan (the bearings pulverized into a silvery liquid).
Old Nov 15, 2016 | 04:15 PM
maytag906's Avatar
maytag906
a "silvery liquid" is different from a "strawberry milky color". That means the ATF is being diluted by water/antifreeze. The silver stuff could be bearings, clutch lining, or a host of metal things.
Old Nov 15, 2016 | 05:11 PM
WhatsAChevy?
A few suggestions....1-Install a separate trans fluid cooler. 2-Drop the trans pan and do a fluid/filter change. 3-Place a magnet in the trans pan before re-installing it (that will capture those pesky metal shavings). 4-Do a coolant flush and fill. I would also suggest using regular coolant (not the 50/50 pre-mix stuff) and dilute it yourself. It makes a difference depending on which region/environment/climate you reside in.
Old Nov 15, 2016 | 05:48 PM
FuzzFace2's Avatar
FuzzFace2
My self if I changed out the fluid & filter and now "got to 3rd and the truck started shaking" I would say time for a rebuild
Before the built is installed by pass the radiator trany cooler and add a big after market one and flush out the lines.
Don't reuse your converter with out getting it flushed out as it still has the "milk shake" inside it.
Dave ----
Old Nov 15, 2016 | 06:57 PM
WhatsAChevy?
Dave ----
True ! Why do we always forget the Torque Converter ?
landmobile
13
Jan 6, 2013 10:43 AM
teddeshong
Apr 30, 2011 02:11 AM
aocabrown
Dec 21, 2007 01:25 PM
cain hughes
1978 - 1996 Big Bronco
Aug 17, 2007 10:50 AM
stingerstang
4 Cylinder Engines
Nov 16, 2004 12:58 PM
