Defrost only
Old Nov 15, 2016 | 05:12 AM
Ar. Hillbilly's Avatar
Ar. Hillbilly
Defrost only
I started driving the old Ford to work last week. I have it running and starting well. Thank you all for the help with that.
I only have high in the heater fan. Thanks to the search I think I have that figured out.
I can't change from defrost to floor. It doesn't have a radio I can reach in and found that there is no cable on the lever for the defrost/floor/vent lever. I can't find that cable hanging anywhere in there. I see a vacuum can/switch and when I actuate it by hand it changes the heat to floor. Can someone give me better details on where this cable should be?
Old Nov 15, 2016 | 05:17 AM
Ar. Hillbilly
I wanted to add that the truck is factory ac.
Old Nov 15, 2016 | 08:24 AM
ctubutis's Avatar
ctubutis
You won't have a cable with factory a/C, it's all controlled by vacuum.
Old Nov 15, 2016 | 01:40 PM
1986F150six's Avatar
1986F150six
Found this in the stickies... maybe it will help! https://www.ford-trucks.com/forums/1...-problems.html
Old Nov 15, 2016 | 01:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If the OP's '83 F150 does in fact have factory installed integral A/C (that is combined with the heater), it has: E3TZ-19988-A .. Temperature Control Cable that is 1983 only.
But, some people don't know that their 1980/86 trucks with A/C have dealer installed A/C that does not have this cable
Old Nov 15, 2016 | 03:40 PM
Ar. Hillbilly
It has part no 18A318. I can actuate it by hand and make it change from defrost to floor. I know the lever has a place for a cable but I can't find anything to hook to it. I'm sure the vacuum going to the heater controls isn't correct. I hear the heat/ cold door slam shut every time I start the truck. It does switch from hot to cold air and seems to be working as it should though.
Old Nov 15, 2016 | 04:00 PM
NumberDummy
1980/86 F100/350 & Bronco with factory installed integral A/C or Hi/Lo Comfort Vent System: There are THREE different 18A318's:
This is probably the one you want:
EOTZ-18A318-B .. Defroster Door Vacuum Control Motor - 2 ports - located on Plenum Chamber (Motorcraft YH-363) / Obsolete ~ 4 available NOS
Old Nov 15, 2016 | 08:16 PM
ctubutis's Avatar
ctubutis
Yes, the temperature control stuff is cable-actuated but he's talking about the vent position controls, those are all vacuum-controlled with factory A/C and care cable-controlled with just a heater.
cornbinder
Jun 18, 2010 12:17 PM
HENDEL JR
Dec 23, 2005 01:34 PM
Sycostang67
Jan 13, 2005 10:14 AM
DT 466Man
Sep 25, 2003 09:28 AM
