352 headers
Old Nov 11, 2016 | 12:37 PM
flip418's Avatar
flip418
352 headers
I'm fixing to swap a 240 ci to a 352 and want to install headers. From what I've read on here you have to unbolt the engine from the motor mounts and jack it up to make room for installation? Is it feasible to put the headers on prior to engine install and put it all in together?
Old Nov 11, 2016 | 01:00 PM
69cj's Avatar
69cj
It would help to know what the vehicle is.
Old Nov 11, 2016 | 01:44 PM
flip418's Avatar
flip418
1966 f100 short box....sorry about that!
Old Nov 11, 2016 | 05:44 PM
69cj's Avatar
69cj
I did that on my Mustang so it should be a piece of cake on a truck. The tranny did have to go in last.
Old Nov 14, 2016 | 10:31 AM
daveengelson's Avatar
daveengelson
Seem to recall the issue is with the starter motor, had to lift engine slightly to insert the headers, do not believe there would be an issue if installed beforehand, may be a bit tight? Suggest setting the engine in place, check to ensure the collectors clear the engine cross member, steering box; particularly if it's a Bendix, the transmission or clutch linkage?
Unfortunately, I do not know the brand of long tube header's the previous owner installed in my 65, it has a 1964 390ci, believe the motor mounts are different than later model mounts, manual Ford steering box, 3 speed w/ O.D., and there are no issue regarding clearance.
Old Nov 14, 2016 | 01:57 PM
resonateur's Avatar
resonateur
I have a set of Sanderson short headers. They both drop in with no problem and good clearance. The right side from above and the left side from below. No unbolting the engine and the starter is not an issue, especially if its a compact starter.
Old Nov 14, 2016 | 04:10 PM
69cj's Avatar
69cj
The OP was questioning wether the new engine with headers would go in at the same time already bolted up.
Old Nov 14, 2016 | 06:25 PM
resonateur's Avatar
resonateur
The OP had a question regarding that he heard you had to unbolt the engine from the mounts and jack it up to install headers. I addressed that, stating my experience with the Sandersons. To speak directly to the other question, I would prefer to install without the headers....only my personal opinion, because you would risk hanging or banging the headers on the motor mounts during installation.
Paul Therriault
27
May 23, 2006 09:57 PM
jor
Jul 13, 2005 10:49 PM
bshackelford711
May 31, 2005 01:21 PM
one9six3
Jan 2, 2002 05:23 PM
