Power loss
Old Nov 16, 2016 | 06:53 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
Originally Posted by just another truck
Good Morning Justin,
I unplugged the ICP, ran slightly rough at idle once warmed up, but still had the Drag, or loss if you will. The default would have let me slide, correct?
With out the chip, is it drivable, or are you suggesting this for the purpose of scanning?
Yes, you can drive it without the chip connected. You will just have a real rompy idle. But it should drive fairly normal.
Originally Posted by Sous
He is suggesting only remove the chip to isolate that as the faulty part on your truck. Without a scan tool of some sort (TorquePro, Forscan, etc) you are looking to replace parts until you find the problem. This is an expensive option and is only guessing at what the cause is.
Yes, removing the chip rules it out or points to it being the problem. This is a temporary test, not a permanent solution.
I am unable to connect to my truck for anything other then MAP and speed. May have something to do with the DP? Might just have to give Justin a call later
The chip does not disable you from using any sort of scan tool. You should be able to pull all PID's and have full diagnostic capability with the chip installed.
so, icp I should be able to unplug, it would go to default, so there would have been no issues, IPR? Sorry, is this the one with the tin nut located on the back of the highpresure oil pump?? There is No disconnecting there is there?
Unplugging the DP, would be fine for base test, however driving I would be dead in the water, correct?
Not dead in the water by any means. Just a rough idle. Exactly as F350-6 explains below...
Originally Posted by F350-6
I'll second the fuel pressure guess. It doesn't always knock or spike the EGT's, but losing power is common. That rubber pick up foot can come apart and plug the fuel pick up line enough to make the truck stall without causing a knock.
Yes unplugging the ICP is ok, No, unplugging the IPR is not. Don't remember what injectors you have. If just single shots, you can run it just fine. It will idle like 60's chevy with a race cam to the point that it's embarrassing at a stop light, but will drive decent.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old Nov 16, 2016 | 08:07 PM
F350-6's Avatar
F350-6
Tell Diane I'm available to moonlight if she wants me to start writing descriptions for tunes on your website.
Old Nov 17, 2016 | 10:10 AM
just another truck's Avatar
just another truck
So, why wont Forscan pick up ANY of my PIDs?,
I know my scan tool just didn't like Fords, but nothing I have tried has been able to watch my engine?
More info today, truck shut down while driving and restarted, Alarms came up listing, Cranks position, Injector failure, ICP failure, electronic feed back so on and so on, and last PCM.. hmmm
Old Nov 17, 2016 | 03:02 PM
Justin@DP-Tuner
PREMIUM SPONSOR
I'll put a good word in for you.
What codes did it throw when that happened today?
__________________
Justin
www.dp-tuner.com
Old Nov 17, 2016 | 07:24 PM
F350-6's Avatar
F350-6
There's no code for fuel pressure so it throws all the other codes that the PCM thinks should be running but are not giving the proper input because the engine stalled.
Do you have a pre-pump filter? Take it off, cut it open, and look for black particles in there. I went through a similar issue when my fuel pick up foot disintegrated and plugged the fuel pick up line. It was random. It never knocked. Once it started to lose power it kept losing it. Adding fuel seemed to help (thought I was chasing a cracked pick up tube at first since I could monitor fuel pressure)
Old Nov 21, 2016 | 10:39 AM
just another truck
Sorry Justin, I did not save them. But will record them then next time..
Truck is getting old, and I am just not able to give her the love she deserves anymore.. Between the shutting off, the power loss, in need of tires, then needing a complete front end..battery going..arghhh.
Then time.. who has time...lol
Old Nov 21, 2016 | 10:47 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Pat, it sounds like you're in a position that you're going to have to drop some money on your truck, even if you do all the work. Front end parts, batteries, tires, none of that stuff is cheap. But they're all parts that do wear out over time.
Old Nov 21, 2016 | 10:51 AM
just another truck
I agree John, you know how it works though, all at the wrong time, and then do I really wish to pick up a payment..
Old Jan 11, 2017 | 06:19 AM
just another truck
So here they are, all of my codes
==OBDII DTC ===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII DTC===
===PCM DTC P0238===
Code: P0238 - Turbo/Super Charger Boost Sensor A Circuit High
Module: Powertrain Control Module
Diagnostic Trouble Code details
Follow the routines in the service manual to resolve the DTC listed.
===END PCM DTC===
===PCM DTC P1249===
Code: P1249 - Wastegate Control Valve Performance
--Possible Causes--
- Short to Ground.
- Plugged WGC Hose or Port.
- WGC Actuator
- WGC Valve.
- Damaged PCM.
===END PCM DTC===
===PCM DTC P0500===
Code: P0500 - VSS sensor circuit fault.
Open VSS circuit.
Shorted VSS circuit.
This DTC may be caused by :
Suspect VSS.
Worn or Damaged VSS drive gear on transmission output shaft.
Suspect PCM.
Faulty or damaged instrument cluster module.
===END PCM DTC===
===PCM DTC P0475===
Code: P0475 - Exhaust pressure control valve malfunction
Exhaust pressure control valve malfunction.
--Possible Causes--
- Short to power.
- Open or grounded circuit.
- Damaged solenoid.
- Damaged PCM.
===END PCM DTC===
===PCM DTC P1282===
Code: P1282 - Excessive Injector Control Pressure
===END PCM DTC===
===PCM DTC P1282===
Excessive Injector Control Pressure.
--Possible Causes--
- Damaged IPR regulator(sticking).
- IPR short to ground.
- Damaged PCM.
===END PCM DTC===
===PCM DTC P1211===
Code: P1211 - Injector Control Pressure Higher/Lower Than Desired (engine running)
===END PCM DTC===
===PCM DTC P0732===
Code: P0732 - Transmission Gear #2 incorrect ratio
incorrect gear selection
Open circuit.
Short circuit
Possible causes are:
shift solenoid(s)
Suspect Internal Transmission Component(s).
Refer to the workshop manual for further diagnosis and repair.
===END PCM DTC===
Last edited by just another truck; Jan 11, 2017 at 06:21 AM. Reason: cause I had more......
SBFD8
17
Dec 27, 2025 01:50 PM
clifford allen
Nov 5, 2015 12:53 PM
TexasRenegade
Feb 23, 2011 06:42 PM
aquaholic
May 8, 2008 09:53 PM
pmasley
Aug 13, 2006 09:18 AM
