Speedometer Cable Replacement
Old Nov 9, 2016 | 06:40 PM
Pooter91's Avatar
Pooter91
Hey fellas, so I broke the speedo cable, apparently it was pinched or i pinched it when putting in a new clutch 6 months back. Anyway it snapped the cable finally, and I was wondering were I could get a new one, its 93" or so. 1965 352 Fe 4X4
Thanks for your help!
Old Nov 10, 2016 | 10:12 AM
daveengelson's Avatar
daveengelson
Link to thread I posted on subject couple months ago, scroll down to #3, perhaps will find listing for the cable U are looking for.
https://www.ford-trucks.com/forums/1...ooth-gear.html
Rather than purchasing aftermarket cable thru online Ford part supplier found the OEM replacement cable on ebay, have not gotten over sticker price yet. Perhaps member's will chime in on their experience regarding the quality of the aftermarket speedometer cable? Suggest purchase tube of the speedometer lubricant?
Old Nov 10, 2016 | 11:23 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Pooter91
1965 F250 4WD: I broke the speedo cable, apparently it was pinched or I pinched it when putting in a new clutch 6 months back.
The cable is not listed as the OP has a '65 F250 4WD, the cables in this linked thread are for 2WD
C5TZ-17260-H .. Speedometer Cable and Housing Assy - 90.60" long / Obsolete
1965/66 F100/250 4WD / No Ford dealer or obsolete parts vendor has any.
The alternative if the housing is OK:
Buy a inner woven steel core kit at an auto parts store, cut it to the correct length, coat it with a fine film of graphite and install it in the housing.
Old Nov 13, 2016 | 09:44 AM
1972RedNeck's Avatar
1972RedNeck
If your housing is bad, you may have to find a speedometer shop and have the make you a custom order cable.
Apr 10, 2018 11:16 AM
Kristof
Jul 20, 2013 12:39 AM
billadas
May 9, 2013 12:31 PM
mezapu
Nov 8, 2009 05:28 PM
judi48
Jul 11, 2008 01:59 PM
