Speedometer Cable assembly 1970 F350
Old May 8, 2013 | 07:11 PM
billadas's Avatar
billadas
I have a 1970 F350 that needs a new speedometer cable assembly. The cable snapped in two locations and can't get it out.
The existing cable housing is about 64" long. the truck has a new process tranny and has a green speedometer gear on the the tranny end. the cable broke off as it came out of the gear and am trying to get the remanents out to reuse. But will need one of these as well if I am not successful. Anybody know where I could find one?
Thanks
Bill billadas@pacbell.net
Old May 9, 2013 | 12:22 AM
Gembone's Avatar
Gembone
The gear you can get for about $10 from your local Ford dealer.
Old May 9, 2013 | 01:06 AM
billadas's Avatar
billadas
Thanks Gembone
Thanks Gembone,
I will chase that down tomorrow. Now I just need to find a cable.
Bill
Old May 9, 2013 | 11:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The existing cable housing is about 64" long. the truck has a new process tranny and has a green (C7SZ-17271-C 17T) speedometer gear on the the tranny end.
The cable broke off as it came out of the gear and am trying to get the remnants out to reuse.
Welcome to FTE
Inside the speedo cable housing is a woven steel core that's supposed to be lubed every so often, but most people are unaware.
The lube dries out, the woven steel core binds up inside the housing and snaps.
Autoparts stores sell a 'universal' woven steel core kit. Cut to length, coat w/a fine film of graphite, install in housing.
The alternative is buying an obsolete speedometer cable assy from one of the following sources, for lawd only knows how much.
C5TZ-17260-N .. Speedometer Cable Assy-64.80" long / Obsolete
Misc applications: 1968/70 F100/350 with New Process 435 & Warner T-18 4 speeds / Ditto 1971 before serial number J70,001.
FORD OF CANTON in Canton TX has 1 = 903-567-4144.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
WESLEY OBSOLETE PARTS in Liberty KY has 1 = 606-787-5293.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 55 = 800-476-9653.
C7SZ-17271-C .. 17T Nylon Speedometer Driven Gear / Available from Ford.
MSRP: $2.84.
Old May 9, 2013 | 12:31 PM
billadas's Avatar
billadas
Thanks for the information
thanks Bill for the help. Will see what they want.
Have a good day
Bill
Apr 10, 2018 11:16 AM
Pooter91
Nov 13, 2016 09:44 AM
Kristof
Jul 20, 2013 12:39 AM
62 squire
Feb 5, 2013 12:38 PM
judi48
Jul 11, 2008 01:59 PM
