Sun visor length
Old Nov 9, 2016 | 11:18 AM
tip49's Avatar
tip49
Sun visor length
Can anyone give me a rough measurement for the sun visor 48-58 F1; I have two in the garage which I assumed were from my truck but they are too long and must be from my 1990 donor. The mounting holes seem to line up so I was thinking of shortening them and then upholstery. I measured 15 1/2" to clear mirror.
Tom
Old Nov 9, 2016 | 12:37 PM
ALBUQ F-1's Avatar
ALBUQ F-1
From the pivot rod's 90-deg bend to the end of visor: 17.5"
Do you have a stock mirror? I am running a wider GM mirror with reading lights and it is a problem getting the visors to clear.
Old Nov 9, 2016 | 07:10 PM
mike.rogers's Avatar
mike.rogers
thats what I got too
mike
Old Nov 9, 2016 | 07:35 PM
tip49's Avatar
tip49
thanks for the replies
I am running the stock mirror, thanks for the measurements.
I will confirm that the bolt up is compatible, then shorten them.
Tom
Old Nov 10, 2016 | 05:36 AM
mike.rogers
the driver side wasn't a problem, but the passenger side kinda is. I have the original small mirror in mine and I have to move it and re-adjust it whenever the wife wants put her side down. Mine originally only had one, but I wanted it to match on the inside.
mike
Old Nov 10, 2016 | 07:01 AM
49willard's Avatar
49willard
mike
I also have the stock mirror and visors. The reason that we have problems with the passenger side interferring with the mirror is that Henry located the mirror off center toward the passengers side (at least on my truck).
I have to wonder if on an original 48-52 with both visors if the original passenger side visor was a little shorter. The aftermarket supplied visors which I have are identical in length. In one of today's trucks (with the current astronomical prices-imho) there would be left and right visors if needed, however, our trucks were clearly no frills work trucks.
Old Nov 10, 2016 | 09:26 PM
tip49's Avatar
tip49
Good heads up on the passenger side mirror
Bill, when I did the measuring it was on the passenger side, so I will measure twice and cut once ! Will make time for it tomorrow, after Remembrance Day services.
Tom
Old Nov 12, 2016 | 09:19 PM
tip49's Avatar
tip49
Sunvisor
Drivers side clears as is, will cut about 2" off the passenger side.
Anyone confirm the bolt size needed to mount the visor to cab? I tried 8/32 but did not fit. Just thought, maybe I need to run a tap in the threads.
Tom
Old Nov 12, 2016 | 09:21 PM
ALBUQ F-1's Avatar
ALBUQ F-1
As I recall they are sheet metal screws
Old Nov 14, 2016 | 09:01 PM
tip49's Avatar
tip49
I'll check that out
'm in the middle of flooring project with hardwood, but will take time to check the screws out.
Tom
Old Nov 14, 2016 | 09:02 PM
tip49's Avatar
tip49
I'll check that out
Thanks Ross !
I'm in the middle of flooring project with hardwood, but will take time to check the screws out.
Tom
mrc00l88
Mar 6, 2016 09:55 PM
JayzDaddy
Jan 18, 2013 05:31 PM
sdetweil
30
Jan 8, 2010 10:08 PM
pluto1
Dec 3, 2005 12:39 AM
palindromelol
Aug 23, 2005 01:23 PM
