Destroyed np203?
Old Nov 8, 2016 | 05:18 PM
WillyV54's Avatar
WillyV54
Destroyed np203?
Still learning on the 500$ 79' f150 only to find the truck will only drive in "low lock" in low, and hi lock it sputters and doesnt want to pull, in hi it has no pull and a slight grinding (assuming the chain)
The motor isnt in great shape to start, and the transmission doesnt like to shift on its own. Not sure where to start on all this
Info on truck
351m
3 speed auto
Np203 (for some reason has locking hubs in front)
Old Nov 8, 2016 | 09:44 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Have you confirmed you have a NP 203? Look at the silver/blue tag on the front. Figure that out 1st.
If it "sputters" then its an engine problem, I'd get that fixed first. Basic tune up stuff like plugs, plug wires, rotor bug, dizzy cap.
But it you hear grinding then that can be a bad sign. Chain stretch and slip is common on a NP203. Drain the fluid and see what it looks like (metal shavings?) NP 203 has oil, NP 205 has 80/90 gear lube.
Np 205 is pretty much bomb proof. Maybe a fluid, filter change and modulator ck is in order for the trans?
Old Nov 8, 2016 | 10:07 PM
WillyV54's Avatar
WillyV54
I checked which case based on the shift in it (5 positions) and i will drain fluid t case tomorrow, i was told id have to rebuild the trans if i drain it so i mever did it. And modulator ck??
Old Nov 8, 2016 | 10:23 PM
wyrm73's Avatar
wyrm73
They do have a conversion kit for the 203 which changes them from full time 4WD. Mine has the locking front hubs too, I just haven't taken it off road yet to confirm that it has been converted like I think it has. I could just put all four corners on jack stands, but what fun is that?
Old Nov 8, 2016 | 10:24 PM
WillyV54's Avatar
WillyV54
I can drove it around the yard now but only working gear in the t case is hi lock (barely) and low lock works perfect
lo and hi doesnt work at all
Old Nov 8, 2016 | 10:29 PM
wyrm73's Avatar
wyrm73
Sorry, that info was more aimed at your question about why you had front hubs. I haven't played with the internals of a T-case too much, so I don't have much in the way of helpful suggestions there.
Old Nov 9, 2016 | 08:15 AM
77&79F250's Avatar
77&79F250
Modulator ck:
Check the vacuum modulator and the line that goes to it.
Check the line for kinks or other problems, make sure it hasn't come off.
If the line checks out, take the line off where it connects to the modulator. If trans fluid leaks out, its bad. If no fluid, it still could be bad. They're simple to replace, disconnect the vacuum line, remove one bolt that holds the clamp in place and the modulator comes out. It has an o-ring seal.
Modulators are identified by the color of the stripe. Pretty much the "go to" one is the black stripe. If they don't show that one in the catalog, go with the green stripe. Avoid the pink stripe. That one is a dual diaphragm version that has two vacuum line going to it. If by chance you have one of these, replace it with one of the other two and use the vacuum line that goes to direct manifold vacuum, cap the other line.
When you pull the modulator out, be careful. There is a pin that goes in the modulator. Sometimes it comes out with the modulator, sometimes it stays in the tranny. If it comes out, don't lose it.
WillyV54
Dec 20, 2016 03:00 PM
'77hiboy
Apr 20, 2008 09:43 PM
marioc956
Jul 24, 2007 04:28 PM
wyazel1
Mar 26, 2007 07:39 PM
DoktorCorb
Apr 28, 2002 06:56 PM
