Bad trans or ?
Old Dec 18, 2016 | 10:55 PM
WillyV54's Avatar
WillyV54
Bad trans or ?
79 ford 4x4
np203
3 speed auto (c6)
anybody have any idea on why my reverse only works when the trans case is in the "lock" positions??? Hubs are locked out. Not sure what's going on here.
Old Dec 19, 2016 | 01:41 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Does it work like it should when the hubs are locked "in"?
Old Dec 19, 2016 | 06:36 PM
WillyV54's Avatar
WillyV54
​​​​​​​yes if I remember correctly.
Old Dec 19, 2016 | 08:17 PM
77&79F250's Avatar
77&79F250
Have you 100 % ID'ed your xfer case? Which shifter do you have? Hint NP-203 is on the left NP-205 on the right.
So your truck came with a NP-203 full time xfer case and someone put lock in/outs on the front axle, right? Did they install the part time kit correctly?
And when you put it in low lock and in D it will not go forward? And only in when put in R will it move?
Time to read up. Maybe the answer is in here? Because I have no idea, but it sounds like something is wrong in side your xfer case.
New Process 203 Transfer Case Tech: Off-Road.com
New Process NP203 Transfer Case Specs
Old Dec 20, 2016 | 12:32 AM
WillyV54's Avatar
WillyV54
Yes I have confirmed it is the np203 AWD. The truck will move forward in any T-case position. But will only reverse when the truck is in either locked position with the hubs out
Old Dec 20, 2016 | 10:02 AM
77&79F250's Avatar
77&79F250
Again I do not know that much about a NP-203.....so that might be normal? maybe a NP-203 owner will chime in?
Can you verify that yes you have the proper lock in/outs and the part time kit is in the xfer case?
And tell me again why you want to drive the truck in LO or HI lock WITHOUT the hubs locked in?
Old Dec 20, 2016 | 01:53 PM
WillyV54's Avatar
WillyV54
as far as I know, the previous owner replaced or put the hubs in, no idea if he messed with the t-case. And I only use the lock positions to use reverse. Reverse does not engage in the other positions except hi and lo lock
Old Dec 20, 2016 | 02:17 PM
77&79F250's Avatar
77&79F250
I am not sure why your truck will not go fwd and only go in reverse when you put it in Lo or Hi lock without the front hubs locked.
Must be an internal xfer case issue, or a NP-203 deal?
Old Dec 20, 2016 | 03:00 PM
JakeHan's Avatar
JakeHan
When you're in R/unlocked, is your front driveline spinning? I had that happen once on a converted 203, I don't remember exactly what mechanically did it, but it was the transfer case. A 203 was a full-time chain driven case, and part of the conversion was to lock out the front driveline, sounds like yours might be coming unlocked in reverse, so you have to manually lock it.
colo76f150
17
Oct 12, 2009 04:53 PM
Scolesy8
Aug 28, 2008 09:13 PM
Shultzie
Dec 22, 2005 08:15 PM
oem78
Feb 11, 2004 12:38 AM
az45
Apr 15, 2003 10:42 PM
