Front or rear sump?
Old Nov 5, 2016 | 05:18 PM
Mr. Ed's Avatar
Mr. Ed
Front or rear sump?
My buddy called to say the oil pan on Henry (351W) is in the wrong place for the IFS he is installing. It looks like the engine is stock with a front sump. (He told me but I forgot). So I need a rear sump but all I see are racing sumps for big bucks. What did you guys do that put 302/351 engines in your '48-'52 F-1s?
Thanks!
Mr. Ed
Old Nov 5, 2016 | 05:37 PM
Oz52F1's Avatar
Oz52F1
BRONCO sump
Old Nov 6, 2016 | 02:13 AM
Mervy49's Avatar
Mervy49
I'm using the rear sump and pan from a 1977 ford van. 351w.
Old Nov 6, 2016 | 09:47 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Mervy49
I'm using the rear sump and pan from a 1977 ford Econoline van 351W
All 1975/97 I-6 & V8 Econolines have a rear sump pan, so find one w/a 351W
Old Nov 6, 2016 | 01:07 PM
CharlieLed's Avatar
CharlieLed
Getting a rear sump oil pan is just half the battle...you must also replace the oil pump and the pickup and one main cap bolt.
Old Nov 6, 2016 | 01:45 PM
NumberDummy
351W oil pump is the same with or without a rear sump pan. It's also the same as 1969/89 351W's used in cars (D9AZ-6600-A replaced C9OZ-6600-A).
But the 351W's rear sump pan uses a different oil pump pickup tube and the special stud is required to attach it to the right side of #3 main bearing cap.
D6TZ-6345-A (replaced C6TZ-6345-A) .. Stud - 1/2" -13 x 3/8" -16 x 4 11/16."
This stud is the same as: 1966 F100 352 4WD; 1967 F100/250 352 4WD; 1968/76 F100/250 360 4WD
Old Nov 6, 2016 | 04:09 PM
CharlieLed's Avatar
CharlieLed
I stand corrected...got confused with the 351 vs 302.
Old Nov 6, 2016 | 04:14 PM
Mervy49's Avatar
Mervy49
The 351w pan should be the same bolt pattern as the 302?
Old Nov 6, 2016 | 05:13 PM
Last chance 53's Avatar
Last chance 53
Ford performance parts sells a pan kit that has the needed parts included. They have 302 and 351 versions.
Old Nov 6, 2016 | 08:30 PM
Mr. Ed's Avatar
Mr. Ed
Thanks for all of the replies. I do not know what I would do without you guys.
Later!
Mr. Ed
Old Nov 6, 2016 | 09:20 PM
CharlieLed's Avatar
CharlieLed
Definitely not...351W pan is a completely different animal.
Old Nov 7, 2016 | 12:25 AM
Mervy49's Avatar
Mervy49
Thanks CharlieLed, I had always presumed they might. That's what I like about here is learning.
Old Nov 7, 2016 | 02:21 PM
The Outlaw's Avatar
The Outlaw
Sorry this is not true either. I have a 68 302 and all I needed to do was add a rear sump pickup and oil pan.
No need to change the oil pump or anything else.
Old Nov 7, 2016 | 02:58 PM
CharlieLed's Avatar
CharlieLed
OK Bill, since I can't seem to get this right...take a look at this pic of a 460 and tell me if this oil pump will work for a front AND rear sump oil pan. I know that on one of the engines I have in my trucks I had to change the oil pump when I changed the oil pan configuration. The front sump pickup pointed down whereas the rear sump pickup pointed towards the rear. If it wasn't the 351W or the 302 then the only engine I have left is this 460. I may be getting old but my memory isn't that far gone yet!
Old Nov 8, 2016 | 10:00 AM
Mr. Ed's Avatar
Mr. Ed
I ordered the oil pan swap kit from Don Wood. It was $120.00, $50.00 less that suggested list price. It includes the pan, gaskets, pickup and dipstick. It is for a 351W in a Fox body.
Thanks!
Mr. Ed
friskyspatula
Jun 25, 2010 01:26 PM
montanarodder
Jun 28, 2007 07:48 PM
Ferngon
May 18, 2007 06:37 PM
BRONCINATOR
1978 - 1996 Big Bronco
Feb 25, 2005 06:19 PM
bluebeast
Oct 27, 2003 11:26 AM
