1990 F250 VIN & ID
Alphabet Soup
I slid under my truck but I think I missed numbers off the axel.
Can you help make sense of this alphabet soup?
13-56-039-908 Borg Warner
F 140 3 1356-46 117832 Foto PA
8(or 6)20598
VIN: 1FTHF26H3LNB57023
3 54 🔽E8TA Z 🔽610312-1
8(or 6)20598
My apologies: In moving this from "Large Truck", I hit the wrong key and fubar'd the title. I have a request in to fix it.
To the OP: Is this a 4 speed manual trans with a non-synchro first gear? It would be a Borg Warger T18 if so.
It looks like you have a Dana 60 axle with a 3.54 ratio.
Is there a warranty plate on the drivers door? It has trans and axle codes along with other info not found in the VIN.
Received 3,138 Likes
on
now I just need to research what some of that is.. like I said it's my first truck -- but thanks for your help
H = Class G Hydraulic Brakes; 8,501-9,000 lbs. Gross Vehicle Weight Rating.
F26 = F250 4WD Pickup.
H = 351W 4V EFI
3 = Check digit, FoMoCo use only.
L = 1990.
N = Norfolk VA Assembly Plant.
B57023 = 1990 Numerical Sequence of Assembly, the trucks specific serial number.
E8TA-ZA ~ 610312-1 = Dana 50 Front Driving Axle / 3.54-1 / No Limited Slip / Manual Hubs / 4,600 lbs. Front Axle Capacity.
The 4 speed could be either a Borg-Warner T-18 (TRANS code: F) or Borg-Warner T-19C (TRANS code: P).
Ed: No Warranty Plates after 1979, replaced by the Certification Label....that from 1970 thru 1979, had very little info on it.
on
Ken Blythen
02-24-2008 01:21 PM
