Missing slave cylinder parts?
Recently I switched slave cylinders on a '95; after much gnashing of teeth & lost brake fluid I bled it by cycling the clutch arm by hand thru it's free travel. Air worked up the line & out the master cyl. Very easy. O-ring stayed on the line so I reused it. It's likely a standard item you could get from a real auto parts or equipment dealer. Same for roll pin, or reuse the old one.
New cyl was chineese aluminum from rockauto.com; hafta see how it holds up. Original cracked & leaked. Thinking the internal parts were better than the replacement I saved it for possible repair parts.
rnelson664
10-04-2008 02:44 AM
93tankus
11-06-2007 03:18 PM
tcd
10-19-2004 07:41 PM
Sentrme
03-17-2003 07:25 PM
