Where to buy the line between clutch master and slave cylinder
You can make your own. Go to the parts store and look through their brake parts catalog (if they have one) and find a brake hose about the right length. Usually one from the brake line to the rear axle will work. Then get a couple of short lines with ends on them and buy fittings to connect them to the hoses.
jt
jt
If you make your own and it's a straight line...no problemo...as long as the flared ends of the new line match your original...and sometimes they don't.
If it has bends you'll need a tubing bender. You'll prolly have to cut the line if it's too long, and if the flared ends of the new tube don't match, you'll also need a flaring tool.
There will need to be a flexible section in it somewhere, the engine moves around and a solid line will soon fatigue and break. If you can find out the size fittings needed at the ends you can adapt them to -AN fittings and use a braided stainless flex line. -4AN is the right size for a clutch line.
I had the same problem when I went to replace the line from the Clutch master to the slave. I used a front brake flexible line and just built a small bracket for each end. The front flex line was off a later model ford with front disk brakes. I chose this flex line because it had fitting on both ends for brackets and steel lines. One bracket is bolted to the bell-housing bolt and has about a three-inch steel line to the slave. The other bracket is bolted to the firewall just below the clutch and brake masters. Then there is a short piece of steel line going to the clutch master. That settup was in use for about 7 years before the truck was torn down for a total restoration. I will be going back to the same method when I get the cab back on the frame.
Cyrus
_____________________
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming... HELL YEAH!!! What a Ride!
Cyrus
59terry
Here is what I did.Buy a new brake line about a foot longer than you need,Bend to fit slave cylinder and just before it reaches the master rap around a spray can.That will give you some flex for motor movement.I did it and it looks great and works fantistic.That fix cost about 4.00 dollars.
Terry
Terry
1957/60 Hydraulic Clutch Line F100/950
B7TZ7A512A .. Hydraulic Clutch Tube Assy-Clutch Master Cylinder to Slave Cylinder / Fits: 1957/60 F100/950.
Who said no one has any new ones? I found SIX in less than a minute.
And, they are genuine Ford originals.
Parts International in Farmers Branch TX has TWO = 888-727-0418
Bob Allen Ford in Overland Park KS has TWO = 800-676-0675
Kinsel L/M in Beaumont TX has TWO = 800-816-2894.
Info source: 1957/63 Ford Truck Parts Catalog / Section 75 / Page 1127.
agui0106
06-10-2012 10:34 AM
j.kenny
20
12-16-2006 07:35 PM
